a/c problems *help*
Old May 11, 2011 | 07:28 PM
brian lam's Avatar
a/c problems *help*
So my last a/c compressor took a **** on me and i had a 04 sedan compressor laying around. I installed it and everything and had the freon vacuumed and charged. I go to turning on the A/C but the clutch on the compressor doesnt engage and is still blowing hot air. I look for an A/C fuse but there are none. The technician at the shops tries checking up on his manual and says that a computer over rules it. He suggests me taking it to the stealership but im sure its real expensive. BTW my car is an 03 coupe
Old May 11, 2011 | 09:36 PM
strykez's Avatar
check the wiring going to the compressor, make sure it's plugged in for a start since you swapped them, if it is try back probing and checking to see if you have power there. There has to be a fuse somewhere just might be under another option.
Old Jun 7, 2011 | 05:13 AM
07Coupe6mt's Avatar
sounds like u need a shop
Old Jun 7, 2011 | 12:52 PM
GR6RR's Avatar
daym! I was hoping to come in here to find an answer. hahahaha
I have a different problem. I got into a car accident and the clutch to the a/c compressor fell off.
I want to buy a clutch off of the internet and slap it back on. Hoping it'll work.
Old Jul 12, 2011 | 04:32 AM
Night's Avatar
yeah almost positive theres an a/c fuse in the fuse box behind the battery. how did you make out? and you said you have a coupe and you put a sedan compressor in?? did it bolt up okay?
Old Jul 12, 2011 | 05:44 PM
brian lam's Avatar
i finally got it fixed about a month ago. But it was really just a 10 amp fuse in the IPDM box behind the battery. And yes the sedan compressor bolted right up to my coupe. However the coupe has 4 mounting bolts and the sedan has 3. Runs perfectly fine for me though
Old Jul 12, 2011 | 07:35 PM
Night's Avatar
great thank you very much
Night's Avatar
ill be installing my sedan compressor to my coupe wish me luck
Old Jul 12, 2011 | 09:05 PM
brian lam's Avatar
just make sure you empty out and install the compressor oil. Goodluck!
chinee
Jun 10, 2024 07:48 PM
champppy
Mar 31, 2020 12:25 PM
Phenomenon9
Aug 9, 2015 01:34 AM
chinee
Aug 8, 2015 10:11 AM
Rehman2009
Jul 27, 2015 03:23 AM
