i just installed a throttle body spacer and now i'm getting a air sound , it doesn't last long but every time i shift it happens
OBX Votex PowerFlow Throttle Body Spacer 1 inch
gary c
close
- Join DateFeb 2005
- LocationValencia, Ca
iTrader Positive Feedback100
iTrader Feedback Score(10)
Liked:1,133 Times in 1,003 Posts
The TBS I installed years ago had an o-ring on one side and extended bolts, is that what yours came with? That's been on my G for so long I almost forget it's there. I did enjoy the extra throttle response I got when it was installed....I've spent worse $$....
Gary
Gary
Yes it came with all that so did I do something wrong or is it couse I have the cold air intake on it too
LoSt180
close
- Join DateMar 2011
- LocationMaryland
iTrader Feedback Score(11)
Liked:468 Times in 379 Posts
If it sounds almost like a turbo blow off valve, or brief sucking noise/whistle, then it's normal with the cold air intake. Mine did that after putting on the stillen intake. If you have a vacuum leak, then the car would run like crap.
i just threw in a z-tube and i have that same blow off valve'y sound. i personally love it. not too noticable but enough to ahve fun with
+1 it is normal. I installed my K&N typhoon CAI and experienced the same thing. Completely normal and also is there real gains with a TB spacer??
