Car "creaks" going over speedbumps...
Old Dec 17, 2004 | 02:20 AM
JKDman's Avatar
Sup all...
As far as suspension mods, I've got Tein S-Techs and Hotchkis Sway bars.
Today, i noticed as i went over some speed bumps, the front right side of my G was "creaking"
Immediately, i thought the shocks went out, but the car isn't bouncing up front (or in the back)
So wondering what it could be? Is it in fact the front right shock that's gone out already? Or is it the S-Techs? (Had those on for 2000 miles) Or is it the Sway bars?
Anyone else have "creaking" "squeaking" noises coming from these mods?
Old Dec 17, 2004 | 05:22 AM
etang789's Avatar
the creak is from the dried up roof seals...reoil the sun roof then u are all set
Old Dec 17, 2004 | 10:28 AM
kgleaves's Avatar
Why do these dry up so fast? I have to do it at every oil change.....really annoying noise.
Old Dec 17, 2004 | 02:45 PM
G3NIU5's Avatar
could be because its getting colder. a lot of cars emit their squeaks/creaks during cold weather. my previous car's sunroof would squeak/rattle during winter then go away during summer.
Old Dec 17, 2004 | 04:03 PM
jayco's Avatar
i was getting the same creaks in my sunroof when i back out of my driveway in the morning - i have a pretty large curb. after re-oiling the seals, it went away.
Old Dec 17, 2004 | 05:49 PM
kenchan's Avatar
I think you didn't lube your swaybar bushings enough.
Use lithium grease inside and outside the rubber bushing.
Old Dec 17, 2004 | 06:31 PM
ck700sl's Avatar
Actually, front end creaking is a common problem in the G. Here is the TSB link for the Sedan. I'm almost positive there is one for the coupe as well.:
http://www.infinitihelp.com/Ownershi.../ITB02-060.htm
As far as I know, this is not a serious problem. Its just annoying to hear the creaking. Good luck.
Old Dec 18, 2004 | 03:58 AM
Buddha's Avatar
its the sway bars, mine creaks over speed bumps too. I jacked the car up yesterday and press against the sway bar and it squeaked. Just take it out and lube it
Old Dec 18, 2004 | 09:12 AM
kenchan's Avatar
Yeh, coat that bushing real good inside and out. Its a pita to remove that bottom engine cover each time.
Old Dec 18, 2004 | 09:40 AM
SixFive's Avatar
See the current thread in the sedans forum re. sways. The Hotckis do not have collars that keep the bar from moving to one side. Grease is also a problem but you everyone wiht the Hotchkis consider looking at your bar's position and putting on the collars we found even if everything sounds ok
chinee
Jun 10, 2024 07:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
newg37
Jul 26, 2015 09:32 AM
Karnicle
Jul 23, 2015 05:08 AM
