injen intake/oem intake
Old Jan 16, 2012 | 09:03 PM
MrTiToG35's Avatar
Ok so you reset the ecu BEFORE any of the parts were thrown on. What's the reason behind that? I've read on most of these threads (which are sometimes confusing as HELL because of all the BS and retards who don't know anything and just want to throw their bad information in) that they reset the ecu AFTER putting aftermarket parts on.
and why the change from MD spacer to Z1? Just asking.
Old Jan 16, 2012 | 09:06 PM
MrTiToG35's Avatar
Reason for asking is because I'm about 300 miles shy of 60,000 and am going to change the air filter but if there is some more power (even 3 hp) to be extracted from a tube and filter then why not put them on instead of some Autozone brand crappy filter?
Old Jan 16, 2012 | 09:09 PM
KnowScott's Avatar
I think people exaggerate the ECU thing on here pretty drastically. The ECU knew we meant business with that many runs on the Dyno.
I brought a MD spacer and they had a z1 spacer, they wanted to see what it'd do with the modified non revup lower plenum (mrev2).
We did 7-8 runs 3 pulls each 2 in 4th one in 5th.
Old Jan 16, 2012 | 09:12 PM
MADtotheA's Avatar
You reset the ECU so that the onboard computer can freshly learn your new mods. Is it neccessary? No. Your ECU will learn on its own after a few days or so of driving. I do it simply because, why not? It takes about 1 minute.
KnowScott's Avatar
There is a lot of misinformation on here for sure not to mention all dynos are different, humidity, temperature and the people operating the car are all variables that change from each scenario.
This was simply my experience this weekend.
Old Jan 16, 2012 | 09:15 PM
MrTiToG35's Avatar
Nice. It's great to finally see someone post an actual sheet with specs after their part installation rather than saying, "DON'T BOTHER BUYING AN INTAKE (granted this was just a z tube and drop in filter) YOU N00B. THEY DON'T DO ANYTHING (HEY! YOU GAINED 3 HP!) FOR OUR CARS AND YOU'LL JUST WASTE YOUR MONEY. IF YOU WOULD'VE SEARCHED YOU WOULD'VE KNOWN." (although sadly searching sometimes leads to more confusion...)
Old Jan 16, 2012 | 09:29 PM
MrTiToG35's Avatar
Very true and I'm sure some people will say that you pulled at a cold temperature and they did their pulls in 150+ degree weather...
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
vamarris
Sep 26, 2015 12:56 PM
