wipers suck on this car!
Old Jan 17, 2012 | 06:32 PM
dg175's Avatar
Hey guys,
I've got an annoying problem with my wipers, on the drivers side, it always leaves a streak diagonally right through my field of vision. Right where the passenger wiper stops, and then on the return swipe downward, the drivers side doesn't remove it. I've replaced the wipers with new ones, and still the same issue. It's like the tension of the wiper spring isn't enough to hold the middle of the blade down on the surface of the glass. Any ideas? Anybody know if and where I can get a replacement spring with a higher tension?
Thanks,
Old Jan 17, 2012 | 06:46 PM
AuAltima3.5's Avatar
Rain X
Old Jan 17, 2012 | 06:50 PM
cto917's Avatar
michelins from costco work pretty well at a very good price. rainx ones are like 16 bucks a pop, not to say that they're bad or anything, just expensive for rubber. i guess it depends on how often you actually use them
Old Jan 17, 2012 | 06:51 PM
dg175's Avatar
I've always used rain x on my car windshields. The issue is that the middle of the wiper does not even make contact with the window on the downward swipe. Since there has been no improvement by replacing the wipers, I'm looking to replace the spring with something with more tension. I have good wipers and have no reason to replace them again.
Old Jan 17, 2012 | 06:52 PM
dg175's Avatar
And coincidentally, I did replace them with Michelins from Costco!
Old Jan 17, 2012 | 06:58 PM
partyman66's Avatar
Did you replace just the blade inserts or the whole wiper?
Old Jan 17, 2012 | 06:59 PM
dg175's Avatar
Whole wiper
Old Jan 17, 2012 | 07:04 PM
davidxu's Avatar
might be your wiper arm. you can get replacements from the dealership.
Old Jan 17, 2012 | 07:10 PM
NepTuneZ's Avatar
No to the rain-x. I bought them, maybe you might have to buy it alittle bit smaller than what it suggest. They suck so bad they do that exact problem u described. Its so damn annoying it makes the streaking sound too as it misses on the way down and leaves that damn diagonal water line on its way up SUCKS SO BAD!!! RAIN X SMASH!!! Might try the icons next if those suck, guess we ish out of luck.
Old Jan 17, 2012 | 07:27 PM
No, not the blades. Like Aquapel? It's just the liquid windshield treatment. When I apply I don't use my wipers for a week or two.
Old Jan 17, 2012 | 07:35 PM
dg175's Avatar
Yeah I checked out the wiper arm, no sign of it being damaged or bent at all. Oh well, I guess I'll have to continue driving with constantly obstructed vision until I find some other way to fix it. One of the many annoying issues with this car I guess..
Old Jan 17, 2012 | 08:04 PM
partyman66's Avatar
Did you have your windshield replaced recently? Maybe your windshield just has a low spot where the wiper can't hit.
Old Jan 17, 2012 | 08:22 PM
dg175's Avatar
Nah, still the original windshield, and 'smooth as glass'
mike730
Jan 12, 2018 04:25 PM
newg37
Jul 26, 2015 09:32 AM
Karnicle
Jul 23, 2015 05:08 AM
