Tire Pressure sensor
Old Feb 5, 2012 | 09:02 AM
Bengus81's Avatar
I have a 2006 Coupe that suddenly decided to have the tire pressure sensor warning light on all the time. It's doing the blink thing upon start up and then stays on all the time--not just when your driving over 16mph as the owners manual states.
Can this be reset,or anyone have an idea what the tab would be at a garage to fix it? The pressure in all the tires is fine,more annoying than anything else.
Thanks!
Old Feb 5, 2012 | 10:23 AM
gary c's Avatar
The TPS warning comes on when you drop below 22 lbs in your tires, can we assume your running at least 35 psi on all four corners? If you're 100% sure of the tire pressure you could take your G into Nissan and have them check out your sensors....Infiniti likes to charge more because they can.
Gary
Old Feb 5, 2012 | 11:01 AM
Bengus81's Avatar
I'll check the pressure once more but....according to the owners manual if there is a malfunction in the sensor system the tire pressure light will blink for about a minute on start up and stay on. If you merely have low pressure the light won't come on until your at 16 mph or faster. Mine is now on all the time.
Old Feb 5, 2012 | 04:09 PM
Grace's Avatar
Avoiding potholes
I know this sounds simple but are you running something other than stock rims? Also mine used to come on randomly in cold weather. Our Nissan truck does the same thing.
Old Feb 5, 2012 | 05:41 PM
Bengus81's Avatar
Grace
They are stock Infinity rims--at least they have an Infinity badge on them. I just got this Coupe a couple of weeks ago and it's six years old so I'm guessing one of those sensors in a rim has gone south. The tire pressure is correct for all four tires.
Old Feb 5, 2012 | 06:21 PM
Grace's Avatar
Avoiding potholes
Originally Posted by Bengus81
Grace
Yup, sounds like it. Take it in to the stealership and have them pinpoint which one w/a diagnostic. When you have your tires changed next time swap it out. A new one will run you 200-ish. I have a bad one, got a replacement and keep forgetting to replace it when I've changed tires.
Old Feb 5, 2012 | 07:32 PM
ThatOneDude's Avatar
I just let the sensor error light stay on. Because I know how to look at a flat tire.
Old Feb 5, 2012 | 10:12 PM
gary c's Avatar
The whole idea behind the TPS is to locate a low tire before you have a flat! With 35 series tires you can't tell if it has 35 or 25 psi so you get out the tire gauge and check each one or look for a nail. When I get the TPS warning it makes noise which gives me an excuse to say, "Oh -hit!"
Gary
Old Feb 5, 2012 | 10:27 PM
You're right. It'd be virtually impossible for me to actually tell before it was too late. I just want to excuse my frugality. However, last year I was rolling 100% stock and sensors had no issues; Next thing I knew, my front right tire ripped to shreds on the freeway.
What am I talking about?
Old Feb 5, 2012 | 10:34 PM
gary c's Avatar
That must have been a wake up call....Ouch! You must have run over something very sharp that took the tire out immediately like 1/2 a beer mug....trying to visualize what would do it.
Gary
Old Feb 6, 2012 | 09:09 AM
Bengus81's Avatar
Thanks for your time and answers. Wouldn't a regular tire store have a diagnostic tool for a bad sensor? I go to a certain one on a regular basis--they also do lube and Oil and other things. I could have them find the bad one (hopefully not more than one) and I could buy the part and have them change it out. Those of you that have changed one did you buy a Nissan equivalent instead of what I would think to be more expensive and that would be one from Infinity? Or are they about the same price?
On this coupe the tires only have about 2k miles,they were changed out when the car was traded in so it will be some time before a tire change.
Old Feb 6, 2012 | 11:59 AM
b_moneyy's Avatar
Basically all reputable tire shops should have an OBDII scanner that can pull the diagnostics from your car and pinpoint the bad sensor. As far as costs go, any aftermarket TPMS sensor will function just as good as the OEM nissan ones. I had a similar issue after changing my wheels, one of the sensors was tightened too harshly on my old wheels and the bolt cross-treaded rendering it unusable. It should cost about $80-100 out the door at a Discount Tire if you have one near you. If you take it anywhere else, an aftermarket sensor is about $75-80 for the part and the shop may charge you approx. $10 for dismounting the tire and another $10 for remounting it, IF your tire's sidewalls are too thin for them to work with (series 30,35, etc). Hope I helped you out a bit!
jsimonk
Dec 22, 2023 03:49 PM
Muski_G
Dec 1, 2023 11:11 AM
joedaddy1
Jul 28, 2015 02:58 PM
stay_tuned
Jul 21, 2015 07:09 PM
