Coupe Random Little Question Thread
Rating: Thread Rating: 2 votes, 3.00 average.
Old Jul 12, 2015 | 04:49 AM
  #961
ScraggleRock's Avatar
Originally Posted by JKL1031
kick plate finisher
Yeah, that's probably what it is.
Old Jul 13, 2015 | 08:36 PM
  #962
nervseele's Avatar
thanks yall, that really helped, still on the lookout for one that is the same color as my interior, grey can be hard to match since everyone seems to have either tan or black interiors
Old Jul 14, 2015 | 02:10 AM
  #963
JKL1031's Avatar
There's a grey?
Old Jul 14, 2015 | 02:49 AM
  #964
nervseele's Avatar
There's a grey?
its like a light stone grey, i really like how it looks but its just that one piece that i cant find. it does look very classy though. (interior pictured is not my car)
Old Jul 14, 2015 | 11:49 PM
  #965
nervseele's Avatar
does anyone know if a g37 shift **** would fit on a g35?
Old Jul 18, 2015 | 05:38 PM
  #966
calig714's Avatar
Dont know if anyone answered this question yet or not but have had it on my mind for a while...
can you pass smog after a tune? like a uprev osiris. i know there getting more and more stricked over the years. wanted to get it after my mods, thanks.
Old Jul 18, 2015 | 06:31 PM
  #967
JKL1031's Avatar
if its tuned to the correct AFR you should. they wont know.
G37 **** will work on G35.
Old Jul 21, 2015 | 01:02 PM
  #968
LCM G35's Avatar
I've got an 07 coupe and am looking to add brembo calipers when I do a full brake upgrade. I know I need the longer bolts for the rears and new lines, but is the swap from base to Brembo basically the same for all years?
Old Jul 21, 2015 | 01:10 PM
  #969
Yes, you can. No one can see that it's been tuned. Dealerships can't even tell. If you purchase the cable tho, you'll always be able to switch back and forth between your tune and the stock ecu coding.
Old Jul 27, 2015 | 10:44 AM
  #970
vlascoff's Avatar
will this fit a 06 coupe?
in the description it states only 06+ sedans
http://www.ebay.com/itm/CCD-Rear-Vie...item2343cca2f0
Old Aug 14, 2015 | 10:38 PM
  #971
JKL1031's Avatar
What oil&water temperatures should I slow down at?
Old Aug 15, 2015 | 06:05 AM
  #972
Hatchman's Avatar
I monitor my water temp via a OBD II bluetooth dongle and app.... Never seen it get over 195 and usually runs around 189.
If it got to over 200F, I'd probably drop back to cruise speed. Though the cooling system will probably be safe to about 220F. After that, I'd start worrying about a hose blowing out as the pressure builds.
Not sure about oil temp.
Old Aug 15, 2015 | 08:44 AM
  #973
JKL1031's Avatar
Auto crossing today. Got a tablet running uprev.
Old Aug 15, 2015 | 08:46 AM
  #974
JKL1031's Avatar
Got in degrees F afterwards and changed the colors.
Just noticed they match the lights tho. Maybe that'd why it defaults to that color combo
Old Aug 15, 2015 | 01:57 PM
  #975
Hatchman's Avatar
I use OBDDash Pro, no oil temp, and default also matches pretty well. Temp spiked to 210 while idling in the garage after a hot drive.
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
