So the G fell on me today
Hey all,
First off, I am alright but I learned quite a lesson. I replaced all 4 rotors and pads on the G today!
Did the fronts with no issues at all, then backed the car into my garage and jacked up only one side in the rear and started to work. Legible I was in the wheel well rep my thecaliper bracket, the G rolled forward off of the shitty OEM trunk jack. Pinned me against the concrete and I was able to squeeze out.
Now I realize I should not have relied on the OEM jack but damn this had never happened to me before. Question is, how should I have gone about getting the car off the ground she I have to replace the rear rotors??
Thanks guys
Thanks guys
I drove ttrank's car solo
Received 1,486 Likes
on
The following 7 users liked this post by Blue Dream:
bigc (10-03-2013),
Drew113 (10-18-2013),
GR6RR (10-01-2013),
ItsA..Gthing (10-01-2013),
LoSt180 (10-02-2013),
and 2 others liked this post.
well, here is the thing. I own currently 2 rear wheel drive cars and I have owned many, from mustangs to an MKIV supra. I have NEVER had this happen to me ever.
If i were to ever go under the car, I always use jack stands and bricks in front and behing every wheel.
BUT, this one rolled right off the jack. This G is my wifes and its an auto. so both front tires were on the ground and I only jacked up one side in the rear, just enough to get the tire off...
what did i do wrong? the crazy thing was, when I tried to jack up the front to get the rear higher in order to get the jack back under it, the MF rolled forward again and smashed the OEM jack....
AHH sorry to have such a tale but man, it scared me good.
How would you guys jack up the car in the rear?
ok right on. dude it scare m so bad, this was a major mistake on my part, im going to go buy a new floor jack asap
the crazy thing is, my hand somehow got crushed so it hurts pretty bad.
anyways, the only issue I'm having is that now my brake light is on for the e brake (auto) and when i pull the pedal backwards it goes off but when i let go it goes back on... any ideas???
I assume you had your E-brake on while jacking it up? The E-brakes in most cars aren't that strong when both rear wheels are on the gorund and that's multiplied by the fact that when you jack up one rear wheel, you're relying on the E-brake for only one of the rear wheels to hold the entire car still. It's just not strong enough to reliably do this.
Next time, chock the other 3 wheels on both sides with wheel chocks (or something else makeshift that won't move if the car tries to roll). You should always ALWAYS AAAAALWAYS use jack stands if you plan on climbing under the car to work on it, regardless of how good of a jack you have. Pneumatic jacks can also fail. Another good failsafe is to put the tire that you have removed from the car under the car on its side (rim shiny side facing up), this way if the car falls off of the jack, it will hit the tire instead of landing on you and crushing you. This is what you're supposed to do if you're ever stuck on the side of the road and changing a tire. It's much cheaper to replace a damaged tire/rim than your own crushed torso, abdomen and head.
I hope you realize how lucky you are. There are people every year who are killed in the same situation that you were fortunately able to escape from without any serious injury.
**** you lucky SOB. Buy a lottery ticket, haha.
I try to keep at least 3 supports under a car when i work on them: two jackstands and a jack, or two jacks and a jackstand. Plus a wheel. You are a lucky ****er.
That said, please never ever get *under* a car with an OEM jack. They are only for swapping tires. Partyman is right right right.
Get some wheel chocks, a jack (a set from sears is like 75 for two stands and the jack), and for christ's sake use your better judgement!
How I lift the rear: Chock front wheel, Jack under the differential, put two jackstands on the OEM pinch welds. After that I usually leave the jack unloaded but just under the diff incase. If it gets in the way of my work, I put the jack adjacent to a jack stand.
From my experience if you are lifting and see the car move alot, say 1/2" or more front to back or side to side, you will need to re-evaluate what is happening, cause something is not right.
