Key Fob Help...
Old Dec 7, 2013 | 07:00 PM
jmed999's Avatar
Question Key Fob Help...
My wife's key fob (2007 G35) only works about 1 in 30 times and we have replaced the battery several times. I'm just going to replace the fob. I looked on ebay and saw some fobs for sale without the uncut key. Couldn't I just buy one of those and put her key in the new fob I buy? If I go this route, would I also have to get the valet key reprogrammed? The listing says something about getting a new valet key cut. I don't understand why if I will just use the same key and only reprogram the new fob. Could someone please explain the process I would need to go through?
http://www.ebay.com/itm/INFINITI-G37...c2d7f0&vxp=mtr
Thanks for your help!!!
Old Dec 9, 2013 | 02:11 PM
partyman66's Avatar
Buy the genuine Nissan/Infiniti Keyfob and just move your actual key over to it.
There is a procedure you can do to program the new fob to work with your car. Here is the procedure:
http://www.infinitihelp.com/diy/comm...am_key_fob.php
Here is the keyfob compatibility chart just to make sure you're ordering the right one:
http://infinitihelp.com/diy/common/remotes/index.php
Old Dec 9, 2013 | 11:27 PM
the93owner's Avatar
I think you can get away with just the reprogram. The key should fit in the slot no matter what shape it's cut in.
Old Mar 3, 2024 | 02:53 PM
Matt_S's Avatar
G35X
Programming description absolutely does not work for 2005 G35X despite it being listed.
2005 G35X remote not depicted on common remotes page.
YMMV
Gemichi
Feb 6, 2023 07:26 PM
"g"orge
Jul 13, 2014 02:43 PM
inthedrink
Jul 2, 2012 01:50 AM
Vectork39
Jan 2, 2011 06:05 AM
