Front rattle, stops when I apply brakes
Hey guys, need some help.
When I go over bumps, even small pot holes there is a lot of rattle coming from what looks like the brakes. When I apply the brakes it stops and everything is quite. I went to a mechanic and they checked all suspension twice and said it is the caliper bushings. So they sent them to some other shop to rebuild. Then they put everything back but the noise is still there... They also thought that it could be the pads but they readjusted the shims and silicone/glued the pads to the caliper to see if that was it. I still have the noise and not sure what it is, they don't either...
Any thoughts?
Any thoughts?
Sounds like the brake hardware is installed incorrectly. Common problem with Nissan brakes. There is a little tag sticking out from the brake hardware and it needs to be through the little loop that's attached to the brake pad. Here is a pic off my car. When the little tab isn't through that small hoop the pads can rattle around and make an annoying noise. Check there first. Should be able to look through the wheel and see it.
That's what I thought at first. But my passenger side was replaced not too long ago. And why would it stop when I press the brakes?
Should they be really tight? Maybe I should take the pads out and do it properly.
I had the same exact problem before...did the same route as you fixed everything but the problem at hand...check your lower ball joint. Mine was cracked and would rattle and clunk a little especially on bump or going slow in general. Check this next before you spend extra money on other things..I had taken it to two different mechanics and they didn't see it all until I did the work myself and found it! If not fixed it will keep getting louder and worse
Yes that clip should be tight inside the hoop. Maybe what is happened is the pads of worn down and now there rattling because they are not tight against the caliper. the idea behind the clip is the hold the pads tight against the caliber so they don't sit around and there flop around
I took it to two different mechanics, one said that the most obvious was control arm bushing. He replaced both sides but original noise is still there. Although made some difference overall.
He said the next usual thing on these cars is compression arm or strut/strut mount.
Did anybody else have issues with these?
He charges too much for labor and I can't just go and replace every part until I eliminate the problem...
kinetek
Aug 3, 2015 04:25 PM
