Hard to shift into Park and Reverse
Old Jun 11, 2015 | 12:19 PM
Mustang5L5's Avatar
Originally Posted by Patrick Bovee
I can it work without that gate completely or no??
The only thing the gate does is move that little red dot around that tells you what shift psoition you are in.
You can prob figure out a way to remove it and just live without the red indicator. You do have the position indicator in the cluster to fall back on.
I beleive all you need to do is remove those 4 phillips head screws and you can prob get it out from there. I'd have to go pull up my trim to see though. It's been some time since i've done it.
Old Jun 11, 2015 | 07:12 PM
Patrick Bovee's Avatar
Mustang I just want to thank you with the help you gave. I was able to unscrew the screws take it apart remove the gate and put back together without a problem feels a lot better my gate looks like it when through hell is that normal wear and Tear?
Old Jun 12, 2015 | 09:41 AM
Mustang5L5's Avatar
It's not a failute I've heard happening a lot. I guess all it would take it to jam up and someone pull the shifter hard from P to D to break it.
Anyway, glad you can shift again now.
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
