OBD II Plug-In?
Old Mar 3, 2005 | 12:19 PM
caelric's Avatar
OBD II Plug-In?
On the coupe, where is the OBD-II plug in located? A fried of mine has an OBD-II scanner that can reset the CEL among other things, along with resetting the ECU; I'm curious where the plug in is located in case I decide to use it.
Thanks
Dave
Old Mar 3, 2005 | 03:04 PM
Zat_Zuma's Avatar
Thanks
Dave
It's located under the dash by the gas pedal. If you look underneath slightly, you'll see the 16 pin plug.
If I could figure out how to attach a picture, I'd show ya.
Old Mar 3, 2005 | 03:09 PM
dwoloz's Avatar
Im pretty sure on mine its located not by the gas pedal but right by the hood release
Old Mar 3, 2005 | 04:58 PM
caelric's Avatar
Cool, thanks, that gives me a good enough idea where to find it
Dave
Old Mar 3, 2005 | 07:21 PM
Msedanman's Avatar
O.F. Administrator
Here you go. The port is located on the underside of the dash to the left of the steering wheel, below and to the right of the hood release.
In the picture, it's the white rectangle flanked on the ends with a philips screw.
Old Mar 4, 2005 | 10:22 AM
Zat_Zuma's Avatar
I stand corrected ...... thanks
Old Mar 28, 2020 | 09:05 PM
quantum's Avatar
2004 g35
There is a pop off panel to the right of the hood release. I popped it off and there is no connector there. WTF? Must I get on my back and look under the dash to find it?
Old Mar 28, 2020 | 09:51 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
When sitting in the driver seat, lift your left knee straight up, it hits the OBD2 plug. No panel to remove. It's possible someone unbolted yours and tucked it up under the dash to use some kind of data monitor plugin device.
Old Mar 28, 2020 | 11:59 PM
caelric's Avatar
Wow, a blast from the past.
Old Mar 30, 2020 | 03:45 PM
herrschaft's Avatar
15 years later, I'm assuming you found it
Old Mar 30, 2020 | 03:47 PM
caelric's Avatar
Well, yeah. Significantly modded my G35 (I think there's a link in my .sig), sold it, and moved on to a BMW M4.
Old Apr 26, 2020 | 03:56 PM
tankmaker's Avatar
The OBD port is slightly to the right of the Engine hood latch
Moving the driver's seat back as far as possible & laying on your back you will see the OBD port (white colour)
Old Apr 26, 2020 | 05:38 PM
caelric's Avatar
Thanks, but, ummm.....got the answer about 15 years or so ago.
Old Apr 26, 2020 | 08:04 PM
cleric670's Avatar
BANNED!!!
It's this guy's fault for hijacking the thread a couple months back
raydeon
Apr 26, 2020 03:48 PM
daman513
Jun 6, 2009 03:43 PM
achau
Jan 19, 2007 11:26 AM
03DSGCobra
Jan 12, 2007 08:30 PM
dkeystone
Aug 23, 2005 11:23 AM
