Sudden drop in rpms after letting off gas
Old Aug 4, 2018 | 06:25 PM
ihateaudis's Avatar
Hi guys. New to the forums. I’m sure this is a nooby question. When I am under 40mph and hit the gas and let off. The rpms act funny. They drop all of a sudden and go back up. My friend says it’s downshifting? I’ve never had a G or Z so I’m not familiar with this. I have a 17 Titan as my other car. The is a 2006 Infiniti G35 automatic. Gas mileage seems fine. Recently replaced camshaft sensors and the crankshaft sensor. Also replaced PCV valve. I’ve seen posts saying it’s normal and others saying it’s not. What do you guys think? I’m taking a small road trip in two weeks and would rather not take the Titan
Old Aug 4, 2018 | 08:05 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Normally a drop or big hesitation in rpms when quickly blipping the throttle like that is a sign of a large vacuum leak. That is not downshift rev matching for an AT that your friend was talking about. I don't think the 2006 had DRM anyways.
Old Aug 4, 2018 | 10:13 PM
ihateaudis's Avatar
Thank you! I haven’t had a check engine light come on so do you think it’d be safe to take on a 500 mile round road trip?
Old Aug 4, 2018 | 10:30 PM
cswlightning's Avatar
You'll probably be fine if it isn't stalling or otherwise malfunctioning, but it's pretty easy to check for vac leaks. Just spray carberator cleaner around the engine while it's running and listen, if the RPMs change you've found your leak. You might be able to "fix" it easily and quickly depending where it is.
Old Aug 4, 2018 | 11:47 PM
ihateaudis's Avatar
I checked for codes and nothing stored or pending. I’ll get some carb cleaner and test it. Thanks guys! I appreciate your advise
Old Aug 4, 2018 | 11:48 PM
ihateaudis's Avatar
As you can see from my username, I had an Audi I hated. It’s made me paranoid with used cars but the Infiniti has been good to me so far. Audi was one repair after another
Old Aug 5, 2018 | 12:06 AM
cleric670's Avatar
BANNED!!!
Throttle body cleaner not carb cleaner, carb cleaner can damage sensors.
Old Aug 5, 2018 | 01:27 PM
ihateaudis's Avatar
Okay I will. Thanks guys! I appreciate all the feedback
G-Ryder03coupe
Drivetrain
33
Aug 6, 2012 08:23 AM
Neu Era
Drivetrain
22
Feb 13, 2010 03:25 PM
JuicedAthletics
Drivetrain
Jul 13, 2009 08:02 PM
greeneggsandham
Mar 22, 2009 03:33 AM
