Engine sputters at high RPM
Old Feb 4, 2019 | 06:37 PM
deeliciousqueen's Avatar
G35 coupe 6mt
Looking to get your opinions about my issue regarding engine sputtering at high RPM's on occasion. It started when I took the car to the track late last year and it only happens during WOT but inconsistently. It threw a code P2A00 which I read and performed dx inspections/procedures etc, no intake air leaks, no exhaust leaks, O2 sensor voltages are fine etc. I also tried fuel injector cleaner but no progress.
I told my tuner about it and he said he did not find anything wrong. As of now, there is no SES but the sputtering is still there occasionally which I suspect could be my fuel system.
How do shops perform or test if fuel system is working properly? I don't want to assume like just take my fuel injectors for cleaning or replace my fuel pump then issue would still occur afterwards. I want to be certain that issue will be fixed.
Car has:
Uprev tuned
New spark plugs
Full bolt-ons
170k
Thank you in advance
Old Feb 4, 2019 | 10:07 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Get the fuel pressure damper sandwich adapter from Z1 Motorsports and put a fuel pressure gauge in the cabin somewhere so you can watch for pressure problems.
If you have high miles on your cam and crank sensors replace them with OEM or Hitachi units.
If you have 60k+ miles on the spark plugs replace them and inspect the coil packs
Do a compression test.
Old Feb 5, 2019 | 12:23 PM
G35 coupe 6mt
Both cam sensors were replaced with oem 5k miles ago
New NGK spark plugs is less than 80 miles ago, coil packs appeared to be good.
How do I know if crank sensors needs replacing? currently no codes that leads to replacing crank sensor though.
Thanks Cleric
Old Feb 5, 2019 | 03:24 PM
cleric670's Avatar
BANNED!!!
Unfortunately you can't test it without an oscilloscope and since it's intermittent and not possible to reproduce consistently you'll never be able to test it without a ridiculously expensive data logging osci meter.
Old Feb 14, 2019 | 12:58 PM
G35 coupe 6mt
Update, after reading lots of info's from other people that experienced the same issue and asking around, I am %95 certain that my fuel injectors are clogged. I'll need to pull it out and send it for cleaning and flow test. Probably not anytime soon because the current weather is soaking Cali, even track events are being cancelled due to the weather. Will update as soon as I get it done and will hopefully fix the issue.
Old Feb 19, 2019 | 10:27 PM
Silversleeper86's Avatar
G35 Sport Sedan 5AT
I've used RC Fuel Injection right there in Torrance. Did a good job. Recommend them when the time comes
Old Oct 1, 2019 | 01:03 PM
Tran251's Avatar
Did you ever find a solution? I’m experiencing the same problems.
06gtfanatic
Aug 31, 2015 03:19 PM
Senko
Sep 27, 2013 10:35 PM
DanielsG
93
Apr 22, 2012 02:27 AM
Anton_Chigurh
V36 Engine, Exhaust, Drivetrain & FI
13
Jan 30, 2011 01:01 AM
marvinmtz
May 16, 2008 05:27 PM
