Front suspension noise
Old Aug 8, 2019 | 11:19 PM
  #31
Urbanengineer's Avatar
Originally Posted by cswlightning
Noise = loose suspension = messed up alignment = potential for excessive tire wear and dangerous handling
Unless it's a sway bar end link, then ignore away..
But it takes like 30 mins to change end links lmao.
Old Aug 14, 2019 | 05:40 PM
  #32
DKole94's Avatar
G35 Coupe '05
Noise gone,
First mechanic was wrong with all parts he did change. Another one was right, did rack and pinion change. Noise was 80% quite but still there, then he did compresion rod.
And it's all gone. First mechanic + second one cost me around 1k...
Thank you guys for all responds!
Old Feb 3, 2020 | 02:02 PM
  #33
DKole94's Avatar
G35 Coupe '05
Hi everyone,
Noise came back on same wheel
Parts that are replaced are from autozone, ball joint, both lower control arms, sway bar link and steering rack. I did only 6-8k miles after repair.
If i even fix this time what would you recommend, maybe only replace bushings but performance ones
Thanks!
Old Feb 3, 2020 | 02:15 PM
  #34
kelman81's Avatar
G35 Sedan Leather Base, Z1 Plenum Spacer, Z Tube (Currently sold to a friend)
... Or you might need to just tighten up your steering rack tensioner screw a little...
Do not touch that adjustment on the rack or any steering rack for that matter! It adjusts the pinion gear to rack lash, has nothing to do with tension. It is set from the factory.
Old Feb 3, 2020 | 02:48 PM
  #35
cswlightning's Avatar
I had a clunk in my steering rack ~25k miles ago. Turned that guy 1/4 turn and all fixed. Maybe tension's not the right word but pretty sure it works by moving the pinion gear closer or further from the rack similar to something like a belt tensioner. Definitely not this guy's problem though.
OP you need to find a mechanic experienced with these cars who can actually show you the problem, I think you've learned throwing parts at it on the advice of random mechanics is never the best solution.
Samahi72
Aug 22, 2018 03:05 PM
G35xChicago
Feb 15, 2017 11:44 AM
JOKER
Nov 12, 2014 01:55 PM
bvlgari23
Jan 15, 2013 10:57 AM
officerdbag
Feb 23, 2010 04:48 PM
