G35 crank no start
Old Jun 21, 2019 | 12:52 AM
Chrisrob8823's Avatar
G35 coupe 6mt
G35 crank no start
Hey guys I’m new to the forum i have a 04 g35 manual coupe with 94k miles i recently got it and as of late it has a crank no start issue. I don’t have the oem key it’s a new key. The fans turn on, the security light stays solid when i try to crank. What could be the issue?
Old Jun 21, 2019 | 03:06 AM
Scorpi0's Avatar
I think our keys are chipped. If your new key isnt programmed to the car, it aint gonna start.
Old Jun 21, 2019 | 03:07 AM
G35 coupe 6mt
The car was running fine before but it randomly died on me, i believe the key lost its connection
Old Jun 21, 2019 | 05:27 AM
Scorpi0's Avatar
Is the check engine light on? Did u read the codes?
Old Jun 21, 2019 | 12:16 PM
G35 coupe 6mt
No check engine light and I’m getting a u1000 code (cannot connect to cann)
Old Jun 21, 2019 | 11:56 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Solid red NATS/IVIS indicator light means it's anti-theft is triggered and you're locked out. These keys have a transponder in them and the BCM must be programmed to accept the key. U1000 should clear when the NATS/IVIS lockout is cleared.
Old Jun 22, 2019 | 01:24 AM
G35 coupe 6mt
Called a lock smith today and tried to get a new key reprogrammed and the computers weren’t communicating with the ecu. What could it be? Fried ecu?
Old Jun 23, 2019 | 01:46 AM
cleric670's Avatar
BANNED!!!
Tow it to Nissan and see if they are able, not all locksmiths have the necessary tools.
It's programming the BCM though, not the ECM.
Old Jun 23, 2019 | 02:06 AM
G35 coupe 6mt
So my key did loose connection to the bcm? It makes sense cause my fans kick on cause the ecu is not receiving power
Old May 31, 2020 | 11:43 PM
Azkid419's Avatar
hey wondering if you ever figured your problem out? My cars having same issues won't start AT check light flashing 16 times, fans kick on, security lights solid, can't connect to my ECU to get any codes reads error everytime.... Got a new IPDM didn't fix the problem. I only have my spare key and don't know how to test the chip in it or even where to start any test to determine anything wrong with the chip to ECU communication
mike730
Apr 24, 2020 10:52 PM
Alex Ant
Dec 13, 2019 10:20 AM
G Thunder
V36 General Tech Questions
Dec 11, 2013 09:45 AM
ImPoppi
Jul 24, 2012 10:58 PM
Skaterbasist
12
May 2, 2007 10:27 PM
