Cam sensor
Old Jan 12, 2020 | 02:29 PM
Lavon38's Avatar
Cam sensor
I have a 2006 coupe and I replaced both sensors and the slip and VDC lights are still on... Idk what to do now. Any suggestions?
Old Jan 12, 2020 | 02:45 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
OBD2 scanner to see what the problem is.
Old Jan 12, 2020 | 04:45 PM
Scorpi0's Avatar
I hope u didnt use aftermarket sensors because they just dont work on these cars. Only OEM!
Old Jan 12, 2020 | 06:57 PM
FreshLikeAG's Avatar
I just replaced the passenger sensor and the CEL will stay on until you reset it. Idk if driving some miles will reset itself
Old Jan 13, 2020 | 08:24 AM
depmike38's Avatar
5 Year Member
g35X 4dr sedan
I had the same problem with an 05 sedan and the problem was the clockspring (spiral cable) under the driver's airbag. Do NOT use one of the aftermarket clocksprings, they aren't made correctly. Does have to be reset at dealer unless you're lucky, I wasn't.
Old Jan 13, 2020 | 12:55 PM
Youre better off buying the NDS2 computer software instead of paying the dealer for what they consider an hour of labor
Old Jan 13, 2020 | 02:43 PM
depmike38's Avatar
5 Year Member
g35X 4dr sedan
Probably should have but I needed it done in a hurry and they flipped it in a day. Even loaned me a new Q50 to drive while they had it and charged, altogether,
$284 and that included installation, re-calibrate and the part so I'm good with it.
Old Jan 14, 2020 | 11:47 AM
cleric670's Avatar
BANNED!!!
The biggest reason for the recalibration is not getting the new cable into the EXACT same position as the existing one. Make a couple match marks on the new one, get it exactly centered, make match marks on the existing one, find out how much it drifted clockwise/counterclockwise and set the new one at the exact same position.
Old Jan 14, 2020 | 02:52 PM
depmike38's Avatar
5 Year Member
g35X 4dr sedan
I did that with the aftermarket clockspring I bought and could not get it in the correct position, something about a notch in it not being cut deep enough. It was like $38 so you couldn't expect much. The dealership had it and figured out what was wrong and felt sorry for me somewhat I guess. There are a lot of things that go through that part and I should've known better.
Old Jan 14, 2020 | 04:09 PM
I had mine pretty dead centered and still got the light. The clock spring had marks on it to line up. If its off by 1 degree it will throw the light
Old Jan 23, 2020 | 06:51 AM
jefferywdonald's Avatar
Work In Progress
Does anyone have a link to the best place for the Nissan DataScan II software and cable? Interested in getting this for diagnostics.
Old Jan 23, 2020 | 01:41 PM
TokkioDrift's Avatar
04 6mt Coupe - motordyne 5/16 ART pipes TDX2; KWv2; Hotchkiss; custom seats.
Conceptz has the cable + software for a one stop shop.
Kennycaine
Jan 1, 2020 11:04 AM
espifrankie
Dec 29, 2019 10:51 AM
scumbagsleeper
Jun 12, 2018 01:41 PM
TheBay
12
Apr 11, 2017 09:27 PM
logicalloco
Jun 19, 2011 09:15 PM
