5/16 MD intake spacer CEL
Old May 20, 2020 | 11:10 PM
cannavis's Avatar
sport
I did a install with a 5/16th MD spacer today did all the reset procedures and did them multiple times and an still getting the high idle CEL. Does anyone have any extra input. I even took the neg terminal off and pumped the brakes to have it come back on 5 mins later... I had 0 CELs before to be clear. 2003 g35 coupe with 1320 down to megan racing y pipe. Thanks for any tips in advanced!!
Old May 21, 2020 | 04:44 AM
Scorpi0's Avatar
U sure nothing is got caught under the plenum when u installed it? No air leaks at the intake?
Old May 21, 2020 | 03:07 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Probably pinched the oil fill neck between the plenums.
Old May 22, 2020 | 07:32 PM
haynV35's Avatar
White G35 Sedan
I got mine stuck the second time i tore it down and was so pissed bc i made it a note to not do that the first time. If this is the case do not only undo one bolt and pull it out. Undo all and torque back down in order, its a good lesson
other than that scanning the code would be the next step
Old May 23, 2020 | 10:33 AM
cannavis's Avatar
sport
So we didnt pinch the oil fill neck, but I got the car warm it had a hanging idle at about 1200 then would drop to 1000, so I did all of the procedures again and it was idling perfect. But it only idles perfect directly after the idle reset. As soon as I turn it off and turn it back on it reverts to the 1000 idle. The plenum was cleaned top and bottom before we installed it.
Old May 23, 2020 | 10:38 AM
cannavis's Avatar
sport
I have a obd2 dongle the code I am getting is p0507 and the actual idle is 987.
Old May 23, 2020 | 11:03 AM
Scorpi0's Avatar
https://g35driver.com/forums/engine-...-g35-help.html
Check out post #9.
Old May 23, 2020 | 11:14 AM
cannavis's Avatar
sport
well i did clean mine with brake cleaner sooo i might have toasted it.
Old May 23, 2020 | 12:01 PM
Scorpi0's Avatar
High probability.
Next time use electronic contact cleaner instead.
Old May 23, 2020 | 03:55 PM
cleric670's Avatar
BANNED!!!
Did you unplug the throttle body harness by chance? Or did you just unbolt throttle body and leave it connected and swing it out of the way. If you unplugged the harness you need to perform the throttle closed position relearn in the FSM section EC under basic service procedures.
Old May 23, 2020 | 07:39 PM
cannavis's Avatar
sport
i swung it out of the way, ive done all 3 procedures about 50 times, to include listening to the TB to make sure its on, i downloaded NDS2 and tried the idle relearn feature bout it fails every time. I might just try to huff it and hope if fixes itself out... I dont drive my g35 a ton but this annoys me i cant figure it out
cannavis
Engine - Intake/Fuel
Apr 4, 2022 08:56 PM
SuperTrooper699
Intake & Exhaust
43
Jul 25, 2011 01:51 PM
skiffangler
Archived Sales
11
Oct 28, 2008 10:08 PM
nismotech1
Aug 21, 2008 10:55 PM
