Engine stopped while driving. Cranks but won't start
Old Jun 23, 2020 | 10:25 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Does your tach move when cranking the engine? You should see it jump up a little if the crank sensor is working.
Old Jun 24, 2020 | 02:13 AM
LegacyG35's Avatar
G35 Basic B
I do not see it move at all.
Old Jun 24, 2020 | 12:07 PM
cleric670's Avatar
BANNED!!!
If it doesn't move while cranking then it's probably not sending a signal.
Old Jun 24, 2020 | 08:48 PM
LegacyG35's Avatar
G35 Basic B
It moved for a second when I sprayed starting fluid in the throttle body. I now know it's not getting fuel
Old Jun 25, 2020 | 12:08 PM
cleric670's Avatar
BANNED!!!
Add one gallon of fresh fuel and see if it starts, the gas gauge is notorious for failing and showing a half tank even though it's 100% empty.
Old Jun 25, 2020 | 08:19 PM
LegacyG35's Avatar
G35 Basic B
I actually filled the tank before it happened. So i only used a gallon before mine died on me.
Old Jun 26, 2020 | 09:23 PM
LegacyG35's Avatar
G35 Basic B
I'm at a loss, I'm just going to have it towed to the dealership.
Old Feb 11, 2021 | 03:36 AM
jk319's Avatar
Infiniti G35 Sedan Automatic no mods
cleric670, you, my friend, is a genius! You solved my problem: engine cranks but doesn't turn, and no fault codes! For nearly 2 weeks I couldn't figure what the problem was. After replacing my old battery, I replaced camshaft position sensor and crankshaft position sensor but the damn thing wouldn't start.
It turned out that my fuel gauge was showing nearly 1/2 full, which completely fooled me. After adding about 1 gallon of fresh gasoline, my car started!!!
Thank you so much.
John
Last edited by jk319; Feb 11, 2021 at 03:38 AM. Reason: my post didn't show where I wanted it
sbrahy
Aug 21, 2019 11:19 PM
tcheetz
Mar 10, 2014 03:36 PM
ChrisKG35
Sep 8, 2013 07:11 PM
sullione
Mar 1, 2013 10:02 PM
nadir
Oct 29, 2006 11:16 AM
