Car just clicks once when I turn the key
Old Sep 18, 2021 | 07:21 PM
G35boot's Avatar
It’s diamond graphite and loud
So I let my friend take my car to McDonald’s he stalled like 4 times in the drive thru and on the 4th time the car wouldn’t start up it started too but after that it just makes a click every time I turn the key I think it’s the starter would appreciate help or to let me know I’m stupid I haven’t had time to really look at it as I’m on duty thanks
Old Sep 19, 2021 | 01:58 AM
Scorpi0's Avatar
Check the connections on your battery terminals and make sure they are clean and tight.
All that stalling might have shaken the battery and loosened the connections.
Old Sep 19, 2021 | 09:04 AM
telcoman's Avatar
Veteran: Army
Do all the lights go out when you attempt to start the vehicle.? That is a sign of a weak or dead battery. What happens when you attempt to jump the vehicle?
If you or someone has a digital voltmeter, measure the voltage across the battery when you attempt to start the vehicle. If the voltage drops to below 8v you have a defective battery.
Good luck
Old Sep 19, 2021 | 12:04 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Single click is usually a discharged battery, put it on a charger and see if it will take any more juice.
Old Sep 19, 2021 | 03:12 PM
G35boot's Avatar
Good luck
thank you boss I’ll ask some of my friends I’m sure they have something I know I have something at the shop that will help me worst case once I catch up on some sleep ima go right out side and check I appreciate you taking your time to respond
Old Sep 19, 2021 | 03:13 PM
G35boot's Avatar
thanks man I’ll go to autozone today if I can’t find a thing to test it I appreciate you
Old Sep 19, 2021 | 03:15 PM
G35boot's Avatar
I wouldn’t doubt it this is the last time I let anyone in my car lmfao 🤣 I’ll go and assess as soon as I can I couldn’t yesterday bc I had duty
Old Oct 9, 2021 | 03:29 PM
shurur's Avatar
2003 G35 Coupe
Get a schumacher battery charger/checker and a nico booster. It is an investment.
Old Oct 9, 2021 | 03:30 PM
shurur's Avatar
2003 G35 Coupe
Get a schumacher battery charger/checker and a noco booster. It is an investment.
Dee G35
Apr 2, 2015 01:07 PM
336G35
Dec 1, 2014 08:52 AM
moLAL24
May 20, 2011 01:11 AM
Cyps
Nov 2, 2010 06:08 PM
schilled
Aug 19, 2009 09:34 AM
