Spec-D white Led strip not working, neither is side markers
Old Dec 16, 2021 | 12:39 AM
koko's Avatar
G35 MT
The white light on the spec d headlights isn’t working, but the turn signals are and so is everything else on the headlight. My side markers also aren’t turning on. I’m guessing a fuse is blown, but which one. And if it isn’t a fuse what is it.
Old Dec 16, 2021 | 01:47 AM
Scorpi0's Avatar
Check fuse #71 on the ipdm.
Old Dec 16, 2021 | 06:44 AM
koko's Avatar
G35 MT
the fuse looks good
Old Dec 16, 2021 | 08:41 AM
Scorpi0's Avatar
It could be something wrong with the headlight assembly itself.
Old Dec 16, 2021 | 08:47 AM
koko's Avatar
G35 MT
how come the side markers don’t work then?
Old Dec 16, 2021 | 01:39 PM
Scorpi0's Avatar
It might be unrelated to your headlight issue. Have u tried changing the bulbs in the side markers? Those do burn out quite often.
Old Dec 21, 2021 | 08:59 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Do you have ANY of the parking lights working? Including the ones in the taillights?
If literally ALL the parking lights are non-functional it could be the internal relay in the IPDM has failed.
If everything worked fine before you installed the Spec-D headlights then that's probably not the issue.
Also check fuse 78 in the IPDM, don't just do a visual inspection, use a DMM and actually measure for voltage while the fuse is inserted by probing the back of the fuse on it's test lead points.
Old Jan 17, 2022 | 08:22 AM
alawa don's Avatar
bmw m3 i like alot blue color
Moderator EDIT: Banned for botting a real estate website in Istanbul...
Old May 16, 2024 | 08:57 PM
Tyler S's Avatar
g35
Were you able to fix this and if so what'd you do?
1sexyG
Lighting
May 5, 2012 07:27 PM
mg2000111
Lighting
Aug 9, 2011 05:38 PM
EDGAR
Lighting
Jan 22, 2011 05:06 AM
Boostedef
Lighting
Sep 13, 2007 01:55 PM
