2003 G35 Fuel Filler Neck
Old Sep 10, 2023 | 08:19 PM
g35life's Avatar
Got a huge puddle of fuel when getting gas... Decided to take the wheel off at home and tried filling up from a Jerry can to ensure the leak was right where he filler neck is...
Looks like it just rotted out, thanks to our salty winters i suppose.
I ended up using rubber gloves and electrical tape to create a seal, used the clamps at the end as well. They ensure that the pipe stays tight? lol
Anyways, I'm like 95% certain to replace the filler neck I would have to drop the subframe and gas tank.
The band-aid solution works... I tested it at a gas station and no leak...
I didnt want to use an adhesive incase someone suggested a better adhesive ? Something that would stick to rust? lol
Thankyou
Old Sep 17, 2023 | 11:21 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You shouldn't have to drop the tank, you can reach the fill neck coupler (the one right at the tank) from under the vehicle. Not sure about the subframe, but I bet there's a way to wiggle that thing out without removing anything else.
humbalum
Aug 1, 2021 04:22 PM
patrickwong
May 1, 2007 02:22 AM
shawnn125
Jul 8, 2006 12:44 PM
Bubbacakes
Oct 31, 2005 09:13 AM
