replacing 05 coupe 19" tires
Old Mar 24, 2005 | 06:02 PM
dropshadow's Avatar
i recently purchased an 05 MT coupe. i still have plenty of time, but i have been pricing out tires for when i need to replace them down the line. i am running into problems finding matching makes of tires at stock OEM sizes - front: 225/40/19, rear: 245/40/19.
what are you guys buying? are you going with the pilot sports? are you able to go with different sizes in the front and rear? something like 225/35/19 & 245/35/19?
i admit i don't understand the whole measurement thing when it comes to tires besides the last number, so if someone could help me, i'd really appreciate it. what are some good matching (front & rear) tires that i can get, and in what sizes? i happen to really like TOYO tires, but they don't seem to make tires in the OEM size.
and what is this whole asymetrical noise? that just means i can't rotate my tires right? or is it asymetrical tread? i realize that i have different sizes in front and rear, so i can't rotate front to back, but does that mean, i shouldn't rotate left to right on my stock tires as well?
Old Mar 24, 2005 | 06:20 PM
G's Up's Avatar
Talking
with respect to tire size the first number is the width of the tire, the second number is the percent ratio of the width to the sidewall (i.e. a 30 profile tire has less of a sidewall since its 30% of the width conpared to a 40 or 45) the last number is the rim size.
the reason as far as i understand you can't simply switch the tires from side to side is the directional tread. the only way to do it is to unmount the tire and remount it on the opposite side (kinda annoying)
as for finding the right size, you dont have to use the OEM tire size, you have a little play within a few dimensions. a rim can accomodate varying sizes of tires in terms of width. if you change the tire too much it will effect your speedometer and odometer.
im not an expert but had the same problem when i bought 18's for my accord
hope this helps
Old May 22, 2005 | 11:18 PM
GRider35c's Avatar
what youre doing by changing the second number is dropping your car, basically you will have less rubber, in height...
if thats what you want, then go ahead, but i would rather go wider, make the first number higher, maybe front: 235/40/19 rear: 255/40/19
now since the second number is a percentage of the first number, since im making the first number bigger, you can also make the second number smaller to compensate... using my numbers will raise your car a tad bit... you can do 35%, but imho it will be too low... ask the experts and see what they say, go to pep boys, just tires or tire rack, see what they recommend...
Old May 22, 2005 | 11:55 PM
BlackonBlackG35's Avatar
My dealer told me the stock 19" tires cost around $250 a piece. After I burn these out, I wil definitely have to buy another brand/quality.
Dealer price's are a lot higher than other tire outlets though...
Old May 23, 2005 | 01:29 AM
g35doc's Avatar
I will be replacing with Toyo T1-R in 245/35/19 front and 245/40/19 rear, as this maintains the stock diameters.
Old May 23, 2005 | 02:25 AM
GRider35c's Avatar
g35doc, was your post a missprint? 245 in the front AND rear, dont u wanna keep your tires staggered??
Old May 23, 2005 | 03:34 AM
g35doc's Avatar
Nope. Not a misprint. Front are 35 series and rear are 40 series. The width is the same but the diameter is not. IMO 225s are too skinny and this setup would make the handling neutral. 245/275 would be nicer but the rear wheel is too narrow to accomodate 275s.
Old May 23, 2005 | 04:54 AM
GRider35c's Avatar
is 1.225 cm gonna make a difference???
Old May 23, 2005 | 04:57 AM
DanielEshaghian's Avatar
I think not...
Old May 23, 2005 | 06:21 AM
g35doc's Avatar
There's also the fact that with oem sized tires there are only 3 options (that I know of) and they're a lot more expensive.
Old May 23, 2005 | 06:22 AM
Rookie84's Avatar
Yup. 245/245 setup will get rid of some understeer that stock G's come with.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
bTanz
Oct 15, 2015 02:31 PM
itschuckster
Jul 25, 2015 08:07 AM
realtalk21
Jul 20, 2015 09:07 AM
nascarbuff17
Jul 16, 2015 10:23 AM
