I think someone's played to much Need for Speed Underground 2!
LOL, can you really do that?
I did a search for "flames" and chose 'search titles only'. only 3 results. here's one:
https://g35driver.com/forums/showthr...ghlight=flames
If you don't want to get flamed (no pun intended), I would recommend not asking about that on the forum. The above thread does have some info for you though.
Usually, in a non fuel injected car, you can just run the mixture really rich, mount a spark plug in the tail pipe with a separate ignition coil connected to it and when you want to make flames just hit the button for the second ignition coil.
Wouldnt expect it to work in a fuel injected car without having a separate fuel injector in the tailpipeor something, but that sounds dangerous! heh
I have those installed....in my pants...usually makes the panties drop, not mine though
My RX-7 does it! When you lift from full throttle you hear pop-pop-pop as the flames go out the tailpipe!
Quote:
That would actually be a good use for that!Originally Posted by SilverII
Great for tailgaters!
Omega Enthusiast
Can you cook with that? Maybe make s'mores or even tail gate bbq....
LOL THIS IS AWESOME, I wish I knew about this in Highschool LMAO!!!
Is this actually safe!?
