rpm needle bouncing...
Old Jul 17, 2005 | 12:56 AM
thejared's Avatar
is it normal for the rpm needle to bounce as you let you foot off the gas?
i own a 05 AT, and when im stuck in traffic on the freeway, or just driving around town normally, whenever i let my foot off the gas to slow down, the rpm needle will drop down very quickly, and hit like 800 rpm or 1100 rpm, then bounce back up a couple hundred rpm. is this normal?? i dont remember if it is normal for the needle to do that or not, but i figured since it was dropping rpm so quickly, i guess the needle wouldnt be able to stop "on a dime" so to say. and it doesnt react that way if i just sit in neutral and rev it.....and also, it idles perfectly in park at 650-700rpm
im not sure though, anyone know?
Old Jul 17, 2005 | 02:33 AM
savefatkids's Avatar
hmm i think mine does the same thing..not too sure though ill check it out next time im driving my car
Old Jul 17, 2005 | 02:35 AM
visualfusion's Avatar
driving a 5AT myself, I've also seen this happen. This only happens in high gears (4,5. sometimes 3). I'm prettysure tis is normal? You were in the manual mode? Or... just automatic? I dont remember seeing it in the full auto mode.
Old Jul 17, 2005 | 02:42 AM
thejared's Avatar
just AT mode. and with mine it seems to happen when in lower rpms, like when you stuck in traffic, or driving the speed limit around town.
Old Jul 17, 2005 | 03:09 AM
ketch's Avatar
yea same thing happens to me ill be at 3 and let off the gas and it will drop to 1 1/2 and then bounce a lil and then stay at 1 or 2.. also ill step on the gas and let off really quik and i will feel my car pull back..anybody else feel this
Old Jul 17, 2005 | 11:10 AM
dave's Avatar
That sounds like the rev-matching feature that the 05 automatics have.
It's raising the engine rpms to make the downshift smoother.
Old Jul 17, 2005 | 02:27 PM
Msedanman's Avatar
O.F. Administrator
It's quite normal. The gauge is reading the engine rpm's which drop quickly, maybe too quickly and then has to jump back up causing a little bounce.
C.
Old Jul 17, 2005 | 02:32 PM
GeeWillikers's Avatar
Walking The Fine Line...
Yes, when I lift completely off the gas I can feel the drivetrain braking the car.
Old Jul 17, 2005 | 03:27 PM
Hotrod's Avatar
you will see the Rpm increase as the car slows and unlocks the converter and shifts to a lower gear, thus increasing the engine rpms
Old Jul 17, 2005 | 03:41 PM
6969g35's Avatar
From: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
C.
same thing here.
I guss its normal on 05
Old Jul 17, 2005 | 03:42 PM
ketch's Avatar
i regret not get a six speed lol.. oh well
06g35
Feb 14, 2022 05:59 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
BradMD_96
Oct 6, 2015 09:31 AM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
