5 A/T Burn out???
Old Jun 25, 2003 | 06:53 PM
RollinHard's Avatar
5 A/T Burn out???
I have my G on order and it should be commin in soon, so I wanna know how to burn out and launch on the A/T (after it breaks in)
Blk/Blk 5 A/T coupe
Old Jun 25, 2003 | 08:17 PM
Msedanman's Avatar
O.F. Administrator
Re: 5 A/T Burn out???
Sure dude, Go into Photo Gallery and scroll down to Video Clips. I'm pretty sure it was an A/T.......enjoy...[img]/w3timages/icons/smile.gif[/img]
<font color=green>GSM</font color=green>
Old Jun 26, 2003 | 12:20 AM
RamboRami's Avatar
G35driver.com Moderator
Easy [img]/w3timages/icons/smile.gif[/img]
1) Turn off VDC (small traction control button on the left of the steering column)
2) press the brakes with your left foot
3) while doing this, press on the gas slowly with your right foot. Keep adding more gas until the brakes feel like they cant hold the car anymore (slipping brakes)
4) let go of the brakes and stomp on the gas! You should get a really good squeal
if you are racing, try to start out at 2,000-2,500rpm
the method i described above is called brake-torquing.....it puts alot of stress on the transmission im assuming, so use it very sparingly!
Just make sure you turn off VDC whenever racing
G35c 6MT DG/Willow
Old Jun 26, 2003 | 02:11 AM
CoolCatGee's Avatar
How do you know it was an A/T? and how did they do it? im thinking by removing the break light Fuse so that they can hold the break down? oh and if you remove the break light fuse when you goto the track you should get better times beaseu you will be able to revhigher when holding the break and gas at same time
Old Jun 26, 2003 | 05:08 AM
Msedanman's Avatar
O.F. Administrator
I didn't say it "was" an A/T. I said "I'm pretty sure"..... from memory. Forget the guy's name, That was way back when the Coupes first came out, but I remember all he did was turn off the VDC.
Let us know how removing the brake-lite fuse goes.
Old Jun 26, 2003 | 02:26 PM
RollinHard's Avatar
Coolcatgee what % tint u got on ur ride???
Old Jun 26, 2003 | 02:34 PM
COUPEDIT03's Avatar
Actually, the 6MT and 5AT were available from the first shipment.
"Dont start none, won't be none"
COUPEDIT03's Avatar
Old Jun 26, 2003 | 05:10 PM
mozy's Avatar
OMG, I was looking for a bigger version of that video for about a year now....someone....give it to me......I'll kill for a bigger version of that vid.
CB 5AT - SAC, CA
Old Jun 26, 2003 | 06:13 PM
CoolCatGee's Avatar
My tint is 5%
philbegas
Jul 8, 2016 07:04 PM
prinny
Nov 22, 2015 11:07 PM
Vqalexisz
Oct 14, 2015 12:48 AM
Learned Hand
Oct 1, 2015 09:02 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
