need help cleaning outside of windows...
Old Aug 11, 2005 | 11:11 PM
u8cheeze2's Avatar
i don't drive a g35c, but i do drive a 91 maxima. my question is, every time i clean the outside of the windows with windex and a paper towel, it always leave a haze or streak marks because when i look at it from an angle in the sunlight, i see the streak marks. Is there a proper way to clean the outside of the windows so i WON'T leave any haze or streak marks? I clean my windows in direct sunlight, if that has any affect on the cleaning process. What method do you guys use to clean your windows?
Old Aug 11, 2005 | 11:39 PM
D87's Avatar
D87
First, wash the windows with soapy water when you are washing your car. Second, after the car is dried, use a micro fiber cloth on the windows to apply the window cleaner, it eliminates dust. Use something like Stone glass cleaner instead. I know that Windex is a logical choice but I always find that it leaves streaks too. You'll also want to use another micro fiber cloth to rub off any haze or if there is streaking. Oh, and sunlight will definitely dry liquids quicker, that and a warm/hot surface. Enjoy!
Old Aug 11, 2005 | 11:44 PM
mc2's Avatar
mc2
invisible glass. it is the best glas cleaner.
Old Aug 12, 2005 | 08:09 AM
Hugo1669's Avatar
+1 and newspaper
Old Aug 12, 2005 | 01:23 PM
u8cheeze2's Avatar
i guess the only time i can clean the glass is early in the morning when the sun is not up. then.
Old Aug 12, 2005 | 02:01 PM
LjN_728's Avatar
But if you use a newspaper to clean the inside windows, be careful not getting the ink print on the dash or moldings. Do clean the window first with soapy water, then finish it off with windex and a rag, not a paper towel. I always find it best when it's a nice sunny day, that way the windex's ammonia dries better when you wipe it.
Only prob about cleaning the windows on the 05' G is that when your door's open, the stupid window lowers 1/3" and if you try cleaning ur windows while the door's closed, you'll start sweat beads. ah...the dilemmas.
Old Aug 12, 2005 | 02:28 PM
Gee Im Fast's Avatar
Some of this streaky-ness is sometimes on the inside man...you know all that breathing with windows closed...try running ur finger on the inside and watch what happens, you'll be surprised.
Old Aug 12, 2005 | 02:35 PM
jimcambell's Avatar
Meguiar's NXT Glass Cleaner with a microfiber. I think it works better than Stoner's Invisible Glass. I've tried both..... along with many others.
No streaking, no residue. This stuff is awesome.
Old Aug 12, 2005 | 02:36 PM
UFGatorG35's Avatar
Originally Posted by Hugo1669
+1 and newspaper
+2 good glass cleaner and newspaper, works every time
Old Aug 12, 2005 | 02:47 PM
gto2050's Avatar
Newspaper.....and any glass cleaner. There's something about the ink of the newsprint?? I dunno but whatever it is, it works. Your hands will much dirtier than the windows when you are done.
Old Aug 12, 2005 | 11:42 PM
94gxe's Avatar
I've had pretty good luck with Armor All Glass cleaner. Moslly use it on trips down to the LA area. Cuts the bugs and dirt off the windows and the headlights, no streaking, no ammonia so it's safe on tint
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Duffy25
Accessories
Oct 12, 2015 01:45 AM
dcsbh1
Oct 1, 2015 03:15 PM
vamarris
Sep 26, 2015 12:56 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
