Door handles peeling off
Old Aug 22, 2005 | 05:37 PM
blueSKYLINE's Avatar
Both passanger and driver interior door handles on my G35C are peeling off. Here is what it looked like a month ago:
it is getting worse and worse and i don't know what to do about it.
Has this happened to anyone else? If so what did you do?
Is it by any chance warrenty covered? should i give it a shot next time i go to the dealer?
any help/advice will be greatly appreciated
Thanks
Old Aug 22, 2005 | 05:48 PM
Memphis's Avatar
I have the same thing happening but my scratches are not quite as bad as yours.......mine has occurred from my watch scratching the driver's side handle. This is a wear and tear occurance and would not be covered by warranty. I was going to replace mine with a new part instead of trying to paint them. I also was going to see if the '05 piece, which is made of aluminum, would fit on my '04. The metal piece might be more durable than the painted plastic.
Old Aug 22, 2005 | 05:53 PM
kenchan's Avatar
05 piece looks like a completely different part, so won't fit.
just order a new one from your dealer. about $20 or so.
Mine had a scratch on it from the getgo, so just got a new one.
I might paint mine if it start to scuff off like that.
Old Aug 22, 2005 | 06:09 PM
Draco24433's Avatar
I have the same problem but it comes from my watch. Mine is actually worse than yours so don't feel bad.
Old Aug 22, 2005 | 06:38 PM
mine was like that when i got the car ... from the previous owner she said it was from her ring .... and its been getting really worse and worse and what is werid is that pretty much no one ever rides with me but somehow the other one is starting to peel off a little bit too
i've got an appointment at the dealer on thursday morning so i will ask them how much it will cost to fix and then once they fix it what can they do to protect it from happenig again couz i'm sure it will ... that is some cheap paint
on another forum i read that they kind of put a clear sticker thing (kind of like the clear bra) on the handles to protect them from peeling ... couz apparently that is a very common occurance
Old Aug 22, 2005 | 09:00 PM
arjunz's Avatar
my dealer replaced it for free..
Old Aug 22, 2005 | 09:10 PM
FrizzleFry's Avatar
one thing you can do is remove it, get some silver spray paint, sand, do a couple coats, then get some clear coat spray. that should prevent it from getting scratched up too easily. of course wet sanding it and polishing it will make it nice and shiny too. spray paint = $4. clear coat = $4-5.
Old Aug 22, 2005 | 10:29 PM
Gee Im Fast's Avatar
Clear bra anyone?
Thank God for Brushed Aluminum in the 05s....
Old Aug 22, 2005 | 10:45 PM
dave's Avatar
It looks like that part is about $20 over at Everything Infiniti.
Old Aug 22, 2005 | 11:02 PM
patrickwong's Avatar
what a piece of dump. i have the same problem.
Nissan still can't get their stuff right.
Old Aug 22, 2005 | 11:10 PM
MikeButcher's Avatar
Well, Nissan got it right...eventually...it just took a little time...the Aluminum piece should hold up a little longer...
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
NailBomb
Oct 28, 2015 07:53 AM
