Momo shift knob rattle
Old Sep 6, 2005 | 12:52 PM
robertc's Avatar
Momo shift **** rattle
Anyone else have a rattling problem with the Momo shift ****? For $100, you think it would be made better.
Old Sep 6, 2005 | 01:01 PM
Gman2004's Avatar
I had rattles with a Sparco shifter. The problem with these types of shifters is that they are not vehicle specific. I kept mine a whole 1 hour before I went back to stock.
Old Sep 6, 2005 | 01:12 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
No rattles on mine.
It's very snug. Don't see how it could rattle
Did you remove the plastic actuator/stem when you took off the OEM.?
Did you use the plastic bushing that came with the Momo?
Old Sep 6, 2005 | 01:19 PM
robertc's Avatar
The button on top is what rattles. Whenever I'm on the freeway or hit something bumpy it rattles. I think the button on top got loose after a while.
Old Sep 6, 2005 | 01:41 PM
BirdMan's Avatar
I've got a Momo **** as well and have never had a problem with rattling. Like inTgr8r remove the blue plastic acutator top from the OEM shifter if you haven't done so already or try inserting one of the larger rubber bushings if you can or tighten the mounting screws on the sides. If all that fails, then contact the distributing company you purchased it from. Dealing directly with Momo would be a pain.
Old Sep 6, 2005 | 02:18 PM
InTgr8r's Avatar
Sounds like you don't have it down far enough on the shaft.
Try loosening the set screws & push it down a little more.
Old Sep 6, 2005 | 02:21 PM
Keith N's Avatar
But, don't push the **** too far down or else you won't be able to move the shifter. I have the Momo and love it.
Old Sep 6, 2005 | 03:11 PM
InTgr8r's Avatar
LOL..
Yup did that the first time too.
Except mine was just low enough that shifting was OK;
but I couldn't take the keys out of the ignition.
Old Sep 6, 2005 | 03:17 PM
OOOOA3's Avatar
Alumni****
robertc, i got the same problem.. i fixed it by putting the rubber bushing inside that came with the momo shifter.. it was FREAKING annoying for the longest time to hear that rattle.. our cars have enough rattles as it is
Old Sep 6, 2005 | 03:32 PM
truplay8's Avatar
THE BATMOBILE
mine is tight and doesnt rattle
Old Sep 6, 2005 | 04:45 PM
robertc's Avatar
Thanks for all your input. What is this rubber bushing you guys are talking about? It's not that really big black rubber piece is it? Cause I thought that was for the manual and if you place it in, then you won't be able to push the button down to shift.
Old Sep 6, 2005 | 04:57 PM
InTgr8r's Avatar
It's a bushing that the setscrews clamp down on.
There should have been 3 or 4 different ones in the package.
Basicaly they're an adapter for different size shafts.
Old Sep 6, 2005 | 05:15 PM
Keith N's Avatar
This link should help. https://g35driver.com/forums/showthr...omo+shift+**** Good luck!
Old Sep 6, 2005 | 06:56 PM
codeflux's Avatar
had the same problem with mine. the top button it what does it. i removed the ****, and unscrewed the screw that hold the button from the inside. then reseated it with some teflon tape tightly. hasn't rattled since.
Old Sep 6, 2005 | 07:08 PM
g_thirtyfive's Avatar
mine does! **** i thought i was the only one wit this problem...anyways its the screws and bottom screwing peice that rattles for me...im guessin due to so much shaking the shifter goes through the screws get loosened which rattle and same wit the bottom peice. hope everyone knows wat im talkin about
Picture Share
Feb 4, 2018 12:41 PM
Tmatheso
Dec 13, 2015 03:24 PM
RWDguy4238
Sep 30, 2015 12:13 AM
blnewt
Sep 25, 2015 01:48 PM
