Differences between Tein S-Tech and H-Tech?
Old Oct 18, 2005 | 10:12 PM
Brian-g35's Avatar
What do most of you have? Best places to get these install in So Cal?
Old Oct 18, 2005 | 11:27 PM
PieroG35's Avatar
Search
You might get flamed for this question.
I suggest doing a search. Lots of info. on this.
Old Oct 18, 2005 | 11:28 PM
Brian-g35's Avatar
<~~~noob here
Old Oct 19, 2005 | 11:09 AM
Kuz's Avatar
Kuz
is it really that tough to answer the man?
Old Oct 19, 2005 | 01:03 PM
vstypicals's Avatar
Most people have the S-techs. They're about .6" lower than the H-techs. Just ask around for any decent shops in your area. I believe the install should run around $100-150. I'm not too sure though. I hope that helps.
Goodluck,
Jeff
Old Oct 19, 2005 | 02:24 PM
Sumlime311's Avatar
yea if i knew i would say. i hate people that just say "search, your going to get flamed" dossh
Old Oct 19, 2005 | 03:23 PM
afr0puff's Avatar
Supa Dupa Moderator
Or you guys could check out the other forums on this site. Perhaps the one that deals particularly with suspension, where you will find this stickied thread:
https://g35driver.com/forums/brakes-suspension/65190-g35-350z-aftermarket-coilover-springs-shocks-spec-s-w-updates.html
Old Oct 19, 2005 | 10:01 PM
636Racer's Avatar
the biggest difference is comfort. the s-techs are plush compared to the h-techs.
Old Oct 20, 2005 | 06:59 AM
neffster's Avatar
understeer/oversteer characteristics, spring rates, camber adjustment, stiffness and the first letters of each type of spring are the main differences.
Too many people place emphasis on ride height. I intentionally avoided this above because there is SO MUCH MORE to dropping your car than getting springs that drop your car .5"...
Thus the reason for the "SEARCH" replies above.
Old Oct 20, 2005 | 09:22 AM
PieroG35's Avatar
You know what I hate......Stupid People.
Especially those who don't know proper grammer.
You expect people to waste their time and explain things to someone who is too lazy to do their own research.
If someone has a question that's fine, but this question is not easily answered as Neffster said. It has been asked many times before.
Old Oct 20, 2005 | 11:10 AM
da mayor's Avatar
H-techs are a simple drop and the S-techs are a lower drop with a higher spring rate which will make the ride a little stiffer. installation in most pplaces are $150 - $200 depending where you live. Definitely the teins are a great choice I have the full suspension on my car.
Old Oct 21, 2005 | 05:16 AM
636Racer's Avatar
I think you got it the wrong way. H-Tech springs have higher spring rates than the S-Tech. S-Tech springs have more sag and gives way for more movement and reduced feedback. They're still a step above the stock springs either way.
Old Oct 21, 2005 | 10:32 AM
vstypicals's Avatar
By the way, it's grammar.
Old Oct 21, 2005 | 11:02 AM
arjunz's Avatar
OWNED!.. LOL
Old Oct 21, 2005 | 12:02 PM
PieroG35's Avatar
Thanks for the correction!
