headlight sensor
Old Aug 8, 2003 | 03:36 PM
retret's Avatar
headlight sensor
I was thinking, I like my car with running headlights but I have to pass "Auto" to turn the headlight on manually and causes it to "blink" which is not good for the bulb, I found a rather simple solution, I put a rounded black tape on the sensor and now I dont have to worry about leaving the lights on in "auto" because it will auto shut off and save the battery from draining and it doesnt blink anymore LOL.
Old Aug 8, 2003 | 04:04 PM
SalTNutz's Avatar
Re: headlight sensor
Why don't you just leave your lights in the "On" position? They will auto turn off when you leave the car anyway.
Old Aug 8, 2003 | 04:08 PM
retret's Avatar
I thought auto shutoff is only in "auto" mode? I tested it on "auto" and it did shut off automatically..
Old Aug 8, 2003 | 04:27 PM
SalTNutz's Avatar
Auto shut off is in all modes, auto turn on is in Auto mode.
Old Aug 8, 2003 | 05:11 PM
Azinwood's Avatar
yup, it will shut off after 5 minutes i believe (however you have it set)
but whats bad about the flicking lights?
g35c-6 speed
http://www.houston-imports.com/
Old Aug 8, 2003 | 06:40 PM
RamboRami's Avatar
G35driver.com Moderator
its not good for the xenon bulb to turn on and off like that, even says so in the manual...
G35c 6MT DG/Willow/HyperGround/BorlaExhaust
Old Aug 11, 2003 | 08:41 AM
RyanGSanders's Avatar
So, when I flash my lights to get someone out of the left lane, I'm wearin' my bulb out???
Drive it like I stole it?
Hell...drive it like I'm making payments on it...
Old Aug 11, 2003 | 10:13 AM
FDNameBrands's Avatar
Turning on and off the HID low beam headlights in fast intervals causes not only the HID bulb to wear out sooner but also the HID ballast and igniter as well which are pretty expensive to replace.
Old Aug 11, 2003 | 10:16 AM
KongzGx's Avatar
unless you have aftermarket HID high/fogs, you're only wearing out regular bulbs when you flash ppl... which aren't that expensive to replace.. and u probably don't use the high's or fogs that often anyway.. so no worries.
'03 G35 Sedan: ivory/aero body/sport/sunroof
Warning: Objects in mirror are FASTER than they appear
Old Aug 11, 2003 | 11:32 AM
Gordgee's Avatar
Administrator
Unfortunately, I think when you flash, this not only activates your highs, but also your HIDs.[img]/w3timages/icons/frown.gif[/img]
<font color=green>GG</font color=green>
Old Aug 11, 2003 | 01:14 PM
This is all good to know...I think I'll just work my way around on the right from now on ;-)
lil beezy
Lights
Dec 23, 2015 05:25 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
n2fooz
Sep 4, 2015 07:46 PM
UT G35
Sep 3, 2015 03:58 PM
