Volk offset help
Old Jun 1, 2006 | 03:43 PM
PAR_SC's Avatar
Volk offset help
I am going to order some gunmetal Volk GT-S wheels for my 05 bs sedan. The wheel size will be 19 X 8.5 and the offset choices I was told for the sedan are 36, 43, or 46. I want to run the same offset front/back on 245/40/19 tires. Can you let me know what offset would be the best choice.
Thanks for your input.
PAR
Old Jun 1, 2006 | 03:54 PM
codeflux's Avatar
first off, you need 245/35-19 tires to match the stock tire size.
for 19x8.5, your perfect offset is +43 (+46 in the front will be very very very close to the shocks; +36 will rub on the fenders).
Old Jun 1, 2006 | 03:56 PM
codeflux's Avatar
i do suggest getting 19x8.5 +43 front, and 19x9.5 +43 rear (yes, same offset). match these with 245/35-19 front, 275/30-19 rear, and you'll have perfect setup.
Old Jun 1, 2006 | 04:07 PM
GLuXuRy's Avatar
^^^i second that
Old Jun 1, 2006 | 04:27 PM
bert039's Avatar
Hey are you sure +36 will rub? There are a few people on this board that have +35 without any rubbing issues. I mean preferrably, wouldn't +36 look better too (closer to the fender and all)?
Old Jun 1, 2006 | 04:31 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
+36 will NOT rub. If you slam the car it will. It wont rub on a 1" drop like the Z springs for example. You can do 19x8.5 with a 36mm offset all around with no problems.
-GP-
Old Jun 1, 2006 | 07:45 PM
G35Lin's Avatar
Multi-Spoked Mod
+35 WILL NOT RUB!! i have no idea where you guys got that.
I have a set of progressive spokes 19X8.5 +35 and 19X9.5 +45 and it fit perfectly!
it also depends on the tires i guess. if you get falken azenis st-115, then you won't rub cause the side wall slants in.
Ed Lin
Old Jun 1, 2006 | 08:24 PM
az1anbeethoven's Avatar
+35mm offset will not rub!! and 245-40-19 is good too...no problems whatsoever...give you a lil more meat and more comfortable...I have 20" with +35mm offset and nowhere close to rubbing, but some that have replied maybe put into consideration that you might want to lower your car, then +43mm would be ideal...
Old Jun 1, 2006 | 09:25 PM
codeflux's Avatar
http://g-owners.com/article_read.asp?id=27
may or may not rub, depending on the drop, and on the tires.
Old Jun 1, 2006 | 11:06 PM
R2 V35's Avatar
If you want aggressive set up. My bro in law is running 19x8.5 +29 front and 19x9.5 +46 rear. No rubbing at all
Old Jun 1, 2006 | 11:09 PM
Chico's Avatar
Ed Lin
+1. Without question...no rubbing.
Old Jun 2, 2006 | 01:10 PM
jimmyc13's Avatar
[QUOTE=codeflux]first off, you need 245/35-19 tires to match the stock tire size.
QUOTE]
I disagree. Running that size is -2.1% from OEM and if you run 245/40-19's (what I have), you're at +1.5% and fill in the fender gap a bit. Just sharing some facts with PAR_SC.
Old Jun 2, 2006 | 02:15 PM
[QUOTE=jimmyc13]
QUOTE]
true true...anything less than +- 3% from oem is good...
Old Jun 2, 2006 | 03:32 PM
PAR_SC's Avatar
Thanks for the responses.
PAR
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
