Calling all "X's" with a lowered suspension!
Old May 24, 2010 | 07:03 AM
  #1561
TurTLe*'s Avatar
Originally Posted by seddon
104 pages and this is your question. Every shock coilover will blow someday. The stock stocks are meant for the stock springs which on average will last about 50k miles depending on driving conditions. If you drop with just springs you reduce that 50k by about 1/2 so now you will probably get maybe 25k miles depending on how much you drop.
Coilovers are like your stock springs and shock it doesn't matter how much you drop you just have the ability to drop and not worry about blowing out your shock as much. Its all about matching the shock and spring that's all.
I've been on here for about 5 years and waited and waited for coils. BC racing is not the best but I can tell you my car looks good lowered about 2'' all around on my winter setup(coupe 19's) and rides better than stock. If I wanna drive it hard I just make a few clips and stiff as hell and handle as hell.
have you or anyone seen how high we can go... looking at it and trying installing just the rears the highest i can get it up to is like 1.25-1.75 drop from stock so far... maybe it looks more since i just did the rears. i like finger gaps for winter mode more like 2-3 where as stock is like 4-5 fingers.
Old May 28, 2010 | 09:13 AM
  #1562
London Boy's Avatar
hey there gang, I am about to get some new sway bars. I just have two questions:
1) what is the downside of stiffer sway bars? as hotchiks has multiple grades.
2) Cusco, Stillen, and Hotchiks all make them. Other than color is there a difference?
Thanks again all!!
Old May 28, 2010 | 11:00 AM
  #1563
seddon's Avatar
With the rears the highest is maybe a 1 finger gap, the fronts I had it up to about 3" over the tire. What I did last winter I took out the rear springs and put my oem springs and struts on took me may 45 mins to do out the rears and the fronts I just adjusted it total time was may 1.5 hours to set it up for winter and the same for the spring.
Old May 28, 2010 | 11:02 AM
  #1564
seddon's Avatar
Thanks again all!!
Even though I still have my X as any everyday driver I am unaware that all those companies make sway bars for the AWD.
Old May 28, 2010 | 11:32 AM
  #1565
Matzo Ball's Avatar
Thanks again all!!
no sways for the X right now.
Old May 28, 2010 | 12:41 PM
  #1566
London Boy's Avatar
Boooo for no sway bars!!
Old May 28, 2010 | 07:53 PM
  #1567
b-lo's Avatar
only rear sways work. I have a stillen rear on my x
Old May 28, 2010 | 08:16 PM
  #1568
London Boy's Avatar
Hey there gang,
I just called the guy Tim at BC racing. Seems like a guy in the know. He is looking into seeing if there are any sway bars in the works. I will let you know how it goes.
Old Jun 1, 2010 | 11:39 PM
  #1569
G35xChicago's Avatar
Originally Posted by mcaron
i just know nothing about coilovers.....sorry?
Get the Coilovers.
Old Jun 2, 2010 | 11:10 AM
  #1570
Gsedan35's Avatar
You guys have a G35X sway bar interest thread floating around, guess this explains why no one is taking any action on it. It won't happen on it's own. You guys deserve much more then just rear bar modding.
https://g35driver.com/forums/g35-sed...ml#post5112454
Old Jun 2, 2010 | 07:43 PM
  #1571
TurTLe*'s Avatar
thanks, yea i figured so about the rear.
I have my coils off the car and adjusted them. looks like there was a LOT more threads on the front VS the rears. I might have to run what your doing for the winter.
Old Jun 2, 2010 | 07:47 PM
  #1572
SLVRG35X's Avatar
with 18's the highest i can go is about a finger and a half in the rear. you can go much higher in the front. these coils are definitley desgined to go low.
Old Jun 3, 2010 | 07:43 AM
  #1573
London Boy's Avatar
Sorry gang,
Just talked to the guy (Tim) at BC racing. There truly is nothing out there in the way of sway bars for our X's. However, if there is enough demand they will seriously look into designing a set. Just wanted to update y'all.
Btw is it worth just getting the rear sway bar?
Old Jun 3, 2010 | 09:33 AM
  #1574
Gusc35's Avatar
there is demand. There has been demand. Theres an entire thread dedicated to it. Tell em to check it out
https://g35driver.com/forums/g35-sed...sways-x-6.html
Old Jun 3, 2010 | 01:05 PM
  #1575
b-lo's Avatar
Sorry gang,
I noticed a diff with my rear set on medium. I would recommend it
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
