Calling all "X's" with a lowered suspension!
Old Nov 15, 2006 | 07:40 AM
  #106
jobe's Avatar
^ You're right no staggered setup on the X, all wheels/tires should be the same size. I believe ma sha1 was indicating you might be able do that setup since they were close enough in diameter size. The perimeter size is off by approximately 5mm though and I'm not sure if the AWD system would detect that. I personally wouldn't risk it. My initial question was can we use the OEM 19" wheels from the coupe with the same size tires all around on the X. I think that the front to rear offset is different and would this matter.
Old Nov 15, 2006 | 09:42 AM
  #107
ma_sha1's Avatar
If you have G35x, Check your spare.
It's a skinny donut, half the width of a regular tyre.
The only thing kept the same is the overall diameter of tire.
If tire width needed to be the same, Infiniti would have had to include full size spare mandatory. Otherwise, if putting different tire width on the X caused problem, infiniti will have to cover it, as they did the same thing from factory.
I have used the skinny spare dounut on my X, it runs fine & no
trigering of AWD lights or damaging transfer case etc.
If that's not enough proof, I don't know what else?
Old Nov 25, 2006 | 05:46 PM
  #108
jovo517's Avatar
350z springs with 20s rides and handles great check it out
http://www.cardomain.com/ride/785972/1
Old Dec 5, 2006 | 02:02 PM
  #109
Garyv01's Avatar
Yo anthony, wutup bro its gary from the G-squad meet (DG sedan)...the drop looks nice bro...you dont have any rubbing issues with your 20's?...or did you roll your fenders?
Old Dec 5, 2006 | 03:04 PM
  #110
apintojr's Avatar
well finally got my stock shocks in from my local shop. they where on backorder. today after work i send them off to KONI to get reworked, and hopfully everything goes right. now the only thing i'm gonna be mad at, is if after i do all of this some dam company comes out with shocks. =P
Old Dec 5, 2006 | 04:08 PM
  #111
jobe's Avatar
Good luck with the mod. Hope this works out well. I'm planning to drop my X too once the snow clears up, probably in April. Planning on revised coupe springs all around. Are the x front struts so different from the sedan with sport suspension upgrade? Can that strut not be modified to fit the x's?
Old Dec 6, 2006 | 11:37 AM
  #112
apintojr's Avatar
The Front Struts Are The Ones That R Diff From The Rwd G35. As Far As I Know The Rwd35 Struts Will Fit On The Awd 35.
Old Dec 6, 2006 | 11:47 AM
  #113
Neal376's Avatar
yea, I have shocks from a 350z in the rear. fit fine
Old Dec 6, 2006 | 08:52 PM
  #114
jovo517's Avatar
wats up bro na it fits fine and looks great but when i put 2 of my boys in the back it was madd low you have to drive carefully
Old Dec 7, 2006 | 07:16 PM
  #115
Garyv01's Avatar
yea i feel you..any new mod plans?
Old Dec 7, 2006 | 08:53 PM
  #116
jovo517's Avatar
na im actually gonna sell my g and get the 335i im really not to happy with the interior set up of the g
Old Dec 7, 2006 | 09:51 PM
  #117
Garyv01's Avatar
yea ill admit the interior is pretty weak...gl with the 335 its a sick ride man
Old Dec 10, 2006 | 08:47 PM
  #118
KrazyEd's Avatar
Ok...from my understanding, the coupe springs drop the RWD sedan .5 inches. So this should drop the AWD sedan approx. 1 inch. Can anyone confirm this?
Old Dec 11, 2006 | 12:37 PM
  #119
seddon's Avatar
Ed that is true I have coupe springs all around. But changing the fronts to Z springs.
Old Dec 11, 2006 | 06:59 PM
  #120
KrazyEd's Avatar
Seddon, Do you have any pics of your rider with the coupe springs? Also, You have any pics of the z springs up front and the coupe springs in the rear? I know you probably have them posted on the boards somewhere but I am at work so I dont have that much time to search. I love the look ot the car with the z springs but I hated the fact that I couldnt really have anyone in the back.
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
