Calling all "X's" with a lowered suspension!
Rating: Thread Rating: 3 votes, 4.33 average.
Old Nov 21, 2009 | 08:53 PM
  #1441
TurTLe*'s Avatar
Originally Posted by G35xChicago
^ have you played around with the dampening settings at all? i still have mine set the same. I feel like the ride is getting bouncier??? who knows...
colder weather.... you have to change up the settings.
same happen to my tokico illumias when i had them on the maxima. cold weather= fluid gets thicker. Then it gets more of a bounce.
Old Nov 23, 2009 | 06:01 PM
  #1442
iiiiiekoiiiii's Avatar
Im about to order my coils ,
i know ive been slackin...
In NY, is it okay to put them on in the winter and raise them up?
Does cold weather effect the coils fluid in any permanent way?
Cause I need to make my life easier, I dont wanna change springs to stock, Then install coilovers in the spring. Its a pain.
Old Dec 2, 2009 | 10:51 PM
  #1443
FlyingLumpia's Avatar
Ok here is a shot from my trip down to cali, courtesy of Candlestickpark. If you want to know I am lowered on bc racing coilover and my wheel set up is 19x9 +32 with 15mm spacer running a 225/40 up front and rear is 19x10 +32 running a 255/35. Yes staggered on a X no fuse pulled.
Old Dec 3, 2009 | 10:57 AM
  #1444
mr2willwin's Avatar
Looking sick bro! I wish I had the spare scratch to get the coilovers... Do you rub your 255/35 at all? I have them in the front and they rub a little on the inside
Old Dec 3, 2009 | 11:11 AM
  #1445
Igor1080's Avatar
Are there any coilovers available for the 2nd gen sedans yet? I'm tired of riding on these eibach springs they really annoy my passengers.
Old Dec 3, 2009 | 02:22 PM
  #1446
I am rolled in the rear so no rubbing. I actually when I first got them I put a 10mm space and had alot of rubbing. I think If I rolled them flat and added some more neg camber I wont have a problem. As for the fronts, I think I could go an extra 5mm
Old Dec 4, 2009 | 10:00 AM
  #1447
Matzo Ball's Avatar
for those running 245/45/18s +30 offset, will they rub on an X when lowered?? Dont want to run any bad camber/toe. Still deciding between Teins or Eibach as I just want approx 1" drop all around.
Old Dec 5, 2009 | 10:42 AM
  #1448
ddpack's Avatar
Sure it's OK to put them on in the winter and raise them up..........that's the advantage and beauty of having coilovers. I'm sure in the winter you're going to have to change your settings a little softer, fluid gets thicker and makes ride harsher.
Old Dec 6, 2009 | 10:33 AM
  #1449
danielfarley's Avatar
Hey Lumpia,
That is looking nice. How do you have the coilovers adjusted? Also can you give me an idea of your whole setup, so I can start looking into doing it myself. What adjusters do you have, and so on? I really appreciate it. I have 18's all around so I don't think I should be worried bout rubbing.
Thanks, Dan
Old Dec 11, 2009 | 04:01 PM
  #1450
Matzo Ball's Avatar
any input??
Old Dec 15, 2009 | 03:25 PM
  #1451
TurTLe*'s Avatar
i'll be doing a little more then that in the summer. coupe 18[s you have are 8 in wide and running just 1in drop should be decent.
i ran 265/40/18 with 18x8.5 +33 in my rears on coupe springs in the back which are about 1 inch or a hair more and it only rubbed when i had people. Same drop with the coils and NO rubbing. I have didn't adjust for camber/toe or have fenders rolled.
G Sedan's old setup was 245/45/18 all around with track wheels. He didn't have any work done AFAIK.
I'm going to run 245/45/18 with my 18x8.5 +33 all around with more then just 1 inch drop on my coils. If i have to get the fenders rolled, i'm going with a small spacer for the stagg effect.
Old Dec 23, 2009 | 08:43 PM
  #1452
seddon's Avatar
Thinking of selling my coilovers anyone interested pm me.
Old Dec 23, 2009 | 11:55 PM
  #1453
Matzo Ball's Avatar
I just put on 245/40/18s. I have a nice wheel gap now (thanks OEM suspension ) Now just to decide: Eibach Prokit or H-Techs?
Old Jan 5, 2010 | 02:43 PM
  #1454
ddpack's Avatar
BC Racing Coilovers................I would save the bucks and do it right. I just installed mine and they are sick.
Old Jan 9, 2010 | 10:39 PM
  #1455
chebamau's Avatar
I have an 03 g35 sedan with Eibach Pro springs and Tokico HP shock installed. Do I need to get alignment after install the Eibach Pro spings and Tokico HP shocks? Thanks.
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
