Alignment results on my "X"
Here are the specs. I would like to know what some of you think of the results. I do not know to much about this.
Front Left(Before): Front Left(After):
Camber: -1.5----------------Camber: -1.6
Caster: 7.6------------------Caster: 7.6
Toe: -.21-------------------Toe: .06
SAI: 6.0---------------------SAI: 6.1
Included Angle: 4.5--------- Included Angle: 4.5
Front Right(Before): Front Right(After):
Camber: -1.5---------------Camber: -1.4
Caster: 6.9-----------------Caster: 6.9
Toe: .02--------------------Toe: .07
SAI: 6.1--------------------SAI: 6.0
Included Angle: 4.6---------Included Angle: 4.6
Front(Before): Front(After):
Cross Camber: 0.0-------------Cross Camber: -.02
Cross Caster: .6 --------------Cross Caster: .6
Cros SAI: -.1------------------Cros SAI: 0.0
Total Toe: -.20 ---------------Total Toe: .13
Rear Left(Before): Rear Left(After):
Camber: -2.6 ---------------Camber: -2.2
Toe: .28 --------------------Toe: .15
Rear Right(Before): Rear Right(After):
Camber: -2.2---------------Camber: -1.5
Toe: .05 -------------------Toe: .12
Rear(Before): Rear(After):
Cross Camber: -.3-----------Cross Camber: -.6
Total Toe: .32---------------Total Toe: .28
Thrust Angle: .11------------Thrust Angle: .02
Originally Posted by Jeff92se
Not too bad at all. They got the rear camber in check and all the toe #s look good. You should have great tire life with these specs. How does it drive?
It drives pretty good. I have a really slight pull to the right but that is not a big deal.
Originally Posted by absolutg
rear toe is pretty high.... i believe spec is 0.0-0.12 ?
krazyed, i'm not sure if i know what i'm talking about but i think a bad toe setting can chew up tires pretty quick. toe indicates whether the tires are pointing in or out on a horizontal plane.
Is there way I can get the stock specs on an 06 coupe with OEM 19s?? The dealership has 05 OEM 18s, are the settings the same regardless of the suspension/wheel size?
for the rear: left the specified range for toe is 0.00-0.22 so I fall into that range with .15
for the rear: right the specified range for toe is 0.00-0.22 so I fall into that range..12
for the rear: the specified range for total toe is .01-.43 so I fall in that range with .28
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
