Installed Unrevised Z SpringsYesterday
Old Dec 3, 2006 | 08:49 PM
  #76
jameyb's Avatar
Originally Posted by marty315
OK, I've read all six pages of this thread and I find myself thoroughly confused. Will unrevised springs and shocks from a 2003 Z work for suspension replacement on an '06 non-sport sedan?
They will work, however, the springs alone won't be an optimal solution for you. The quote below is from a previous post in this thread by Gsedan35 (commonly accepted on this forum as somewhat of a G suspension guru).
Originally Posted by Gsedan35
Non-sport sedan shocks ply the unfortunate path of compromising dampning performance in a attempt to gain ride comfort vs commiting more R&D time at the factory level to get the valving right. I didn't find the non sport suspension all that softer then the oem sport suspension so much as I found it's shocks more poorly valved. Adding more spring stiffness, would be a receipe to make things worse.
I am with anyone that want's to do things without spending money without cause, but at the very least I would recommend a upgrade to oem sport shocks, revised oem Z shocks, or 05/06 G coupe shocks off a donor car with oem 19's. Tokico D-specs would be better still of course, and IMO well worth the $500 investment.
Unrevised Z springs are stiffer than sedan non-sport springs. I would take his suggestion and upgrade shocks at the same time to any of the options he lists above.
Old Dec 3, 2006 | 09:06 PM
  #77
OCG35's Avatar
I was in the same boat a few days ago... Was considering OEM 3350Z springs... after reading boatloads of info out here I realized that with non-sport sedan suspension the unrevised springs do no good... either get full revised suspension (springs and shocks) or unrevised springs with 05-06 Z or coupe shocks, or aftermarket shocks.
I decided to just get Eibachs - they are designed for stock shocks and supposedly the R&D for the sedan Eibach Pros was done on a non-sport G sedan... this was posted by GSedan35 and I called Eibach directly (to ask some other questions)... They in fact used one of their employee’s car for R&D and he confirmed it was a non-sport sedan... So Eibachs for me... Good luck.
Old Dec 4, 2006 | 12:31 AM
  #78
G35Dreamz's Avatar
I picked up a set of unrevised springs for my sport shocks today. I hope it drives more solid. I'm use to coilovers, sway bars, wider and stickier tires on my Accord and the 4x4 on my G, i have to be careful on sharp turns.
Old Jan 23, 2007 | 01:20 PM
  #79
jimmyc13's Avatar
Originally Posted by TunerDad
Hey bro just remember if you need an alignment adjustment due to camber and/or toe being out of spec you will need some more aftermarket parts. Camber kit for rear and new adj. A arms in th front. I'm dealing with that right now form my Z springs. Your car looks good. The more you drive it lowered the more you will love that set up.
tunerDad
So did you need to get a camber kit? Any issues?
Old Jun 8, 2007 | 05:34 PM
  #81
perry05G35's Avatar
get it through eibach their camber kit is actually the same kit that SPC sells for 218 dollars but the eibach (SPC) kit is 140.
Old Jun 8, 2007 | 11:44 PM
  #82
samecraig's Avatar
I just got the unrevised z springs installed today. First impression: more stable, flatter in turns, less dive and squat, not floaty at higher speeds, and the ride is not degraded at all as far as I can tell. All that was expected, or hoped for, so I'm happy. I will say I can understand why some use G35 coupe springs in the rear, where the gap is slightly less in the back than the front with all z springs. But the car sits level so I have no problem with that.
Old Mar 24, 2010 | 05:14 PM
  #83
HighDecepticon's Avatar
Ok. I too am a bit confused... I have the OEM sport suspension on my '06 G35 Sedan. I would like to lower it, and use the stock sport shocks.
Revised or unrevised?
350z rear springs or coupe rear springs?
Old Mar 24, 2010 | 05:35 PM
  #84
S 854's Avatar
^Your OEM spring rates:
Oem linear springs
G35 coupes with oem 17’s & 18’s (non-sport)
G35 sedan’s with sport suspension
350Z’s 2003/2004 (unrevised)
Front:314 Rear:342
From this thread:
The Godfather of All G35 Aftermarket Springs & Coilovers Thread
You're looking for unrevised 350z springs from 2003-2004 350z's. Matching up spring rates will help with shock life. I also have a 2006 sport sedan, and had 350z springs front/back for awhile. The front wheel well makes it look like the front sits higher. Just switched out the non-sport g35 coupe springs in the rear recently to even things up a bit.
Here's alot of pics in this thread:
G35 Sedans with 350Z Suspensions Thread
Old Mar 25, 2010 | 12:49 PM
  #85
RADIOGUY21's Avatar
holy old thread. Yes go with unrevised springs from either the G coupe or Z to match the rates of your sport shocks/struts. If you have more than 50K miles, I would swap everything and go with a complete revised Z suspension. If you're under and the shocks/struts are in good shape, it just a matter of a 1" drop in the rear with the Z springs, or about a 1/2"-3/4" drop with the coupes.
Personally I went with the G coupe springs in the rear because I felt the Z springs gave too much of a drop in the rear. Its more evened out with the coupe springs in back. Ive been on this setup for about a year with my sport shocks and the car has been riding great.
Old Mar 25, 2010 | 01:12 PM
  #86
oscar_g-sedan06's Avatar
i also installed 350z revised springs yeserday i love it just need to get coupe springs for rear this week..got all 4 350z springs with 5k miles $35 all 4 den coupe springs with 17k miles for $40 all four can't beat that knw need to sale coupe front springs and 350z rear springs
Attached Thumbnails Installed Unrevised Z SpringsYesterday-3r3.jpg   Installed Unrevised Z SpringsYesterday-kk.jpg
Old Mar 25, 2010 | 02:58 PM
  #87
RADIOGUY21's Avatar
im pretty the revised the Coupe and Z springs are the same length.
Old Mar 25, 2010 | 06:40 PM
  #88
i mean unrevised
Old Mar 26, 2010 | 03:39 PM
  #89
zhadow04's Avatar
I have a question? I have tokico hp blue shocks and I was wondering if it's ok to use them with revised front z springs and the rears with couple springs?
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
