Difference was NIGHT and DAY!!!
Old Nov 26, 2006 | 11:14 PM
  #151
molidor01's Avatar
Here is a FAQ form K&N:
20. How do I know when to clean the filter?
The general rule of thumb is that the filter needs to be cleaned when the dirt build up gets as thick as the wire mesh. The usual interval is 30,000 - 50,000 miles depending on driving conditions. We recommend that you check your filter about once a year in normal usage.
Just a little FYI..
Old Nov 27, 2006 | 01:04 AM
  #152
chobble19's Avatar
Originally Posted by Floyds_racing
shoot me a pic Im shure I got one or can get one for you!
do u have the saem star screws securing ur maf in? im not sure if mine is is different or what b/c of the injen
Old Nov 27, 2006 | 01:08 AM
  #153
chobble19's Avatar
Originally Posted by RocketG35
The thing you need to clean is the intake tube...it is locked into intake with the four T25 Torx screws you see on the back of the Air Filter box. You'll see a wire module plugged into it. If you unclip the airbox and remove the z-tube, you can easily move the back of the airbox to see the MAF sitting behind a mesh screen. There is a nylon strap holding the MAF housing to the MAF wire plug...I didn't cut it so you can only pivot the housing around.
So...I actually removed the torx screws to release the housing, pulled the MAF out of the housing, and blasted the sensor and the wire plugs. Some say not to do it...but I was careful. I believe you can clean it fairly well without removing the housing and spraying it through the mesh/housing.
i got the injen cold air system and it seems to only have 2 screws securing it? where'd u get the bit for em!? ill get some photos up 2morroraa
Old Nov 27, 2006 | 03:51 AM
  #154
RocketG35's Avatar
Why do I bother to DIY???
I got the bit from a drill/screwdriver bit set that I got as a gift. Home Depot, Lowe's or Sears should have it. Sears and Lowe's are good for finding individual bits, sockets, almost everything! I can't recall what size I used...will try to check tomorrow.
Old Nov 27, 2006 | 03:55 AM
  #155
boe's Avatar
boe
good info's
Old Nov 27, 2006 | 09:15 AM
  #156
Floyds_racing's Avatar
to be honest i will have to look!
Old Nov 27, 2006 | 10:06 AM
  #157
chobble19's Avatar
gonna check out the local hardware shop to see if they have any of these "tamper resistant" torx 20 screwdrivers
EDIT: just got back and they only had the torx 20 bit! cost me 5 bucks!
Old Nov 27, 2006 | 04:01 PM
  #158
cool Just picked up a can and cleaned mine so we will see over the next few days what it does!
Old Nov 27, 2006 | 07:22 PM
  #159
s0nicstr1fe's Avatar
You should clean your maf just as often as you clean your filter (IMO)
You should also use products that are MADE to clean the sensor with...
That electronic cleaner was meant for keyboards and computers(inside and out) the non-residue means whatever chemicals in it evaporate fast. This could possibly damage sensors like the MAF that uses its serfice to determain a lot of things. Quick evaporating-god-knows what chemicals used for fiberglass(circuit boards) and plastic; in my opinion; could possibly (yet again) damage your sensor.
Probably the reason your feeling power- (and I say probably so don't hold it against me if I'm wrong) is because the signal your MAF is sending back is telling your ECU that the air is cold and in exchange pouring more gas into cylinders, making your motor run lean, and eventually messin up your ride because the motor thinks its getting cold compressed air when your really sending in more heat(the enemy).
Just something to think about! You should stick with products that are made to do the job.
Not trying to pick on you, just trying to save you from heartache of messin up your ride.
Old Nov 27, 2006 | 07:32 PM
  #160
chobble19's Avatar
...................................like the CRC cleaner
Old Dec 1, 2006 | 03:49 PM
  #161
chobble19's Avatar
FINALLY managed to clean it and it still looked new! no filth anywhere on the maf...i cleaned it anyway with the crc all is well
btw i have about 26000 miles
chinee
Jun 10, 2024 07:48 PM
Frostbite91
Jul 27, 2015 05:25 AM
itschuckster
Jul 25, 2015 08:07 AM
joel extreme
SOCAL Meetings & Events
Jul 23, 2015 04:13 AM
