Difference was NIGHT and DAY!!!
Old Aug 16, 2006 | 12:54 PM
  #31
scorcher76's Avatar
Electronic Contact Cleaner
Originally Posted by chobble19
....where the helllz can i get an MAF cleaner and intake cleaner....i would doubt discount auto parts would have it?
Try any electronics store. Make sure your cleaner doesn't leave residue (should say so on the can).
Or better yet, order the CRC MAF Sensor Cleaner.
Alex
Old Aug 16, 2006 | 01:03 PM
  #32
chobble19's Avatar
Question
thanks but order the CRC from where?????
Old Aug 16, 2006 | 01:06 PM
  #33
scorcher76's Avatar
CRC MAF Cleaner...
I did a google and this is what I found : http://www.midwayautosupply.com/deta...tion.asp?19596
Old Aug 16, 2006 | 01:12 PM
  #34
chobble19's Avatar
Thumbs up
sweeet ordered it! thanks man
Old Aug 16, 2006 | 01:26 PM
  #36
ttrank's Avatar
Grocery getter
electric fan conversion....not an expert but im guessing it makes things cooler
No, the older sedans have a fan which is run by the motor. This takes a little power away from the engine. The conversion is to add electric fans like the newer ones have.
Old Aug 16, 2006 | 01:40 PM
  #37
ttrank's Avatar
Grocery getter
Looks like they have the CRC cleaner at NAPA so I will go get some today.
Old Aug 16, 2006 | 02:21 PM
  #38
vodkarocket's Avatar
Modded Member
hehe Thanks! Hmmm, maybe you have an idea how to replace brakes pads? heheh
Alex
Easy, where are you located?
Old Aug 16, 2006 | 02:38 PM
  #39
cato's Avatar
SouthernComfort Moderator
I went to the auto parts store at lunch and bought a can of this stuff. The guy said they just started carrying it. Will try it very soon as my Stillen airbox is due to be opened. I just cleaned the cone filter and realized I re-installed it without the metal band securing the cone filter to the venturi input.
Old Aug 16, 2006 | 02:47 PM
  #40
MyRedG03.5's Avatar
The easiest way to describe it was before cleaning the MAF, acceleration didn't felt linear, especially from a stop...as if something is holding it back from going faster...then as the RPM rises then you feel the surge of power and the car advances. In fact, when accelerating from a stop, i kinda feel hesitation for half a second, then a jolt and the car advances...
Alex
Me too. Have 66,000 miles on my 03.5. Going to pick up some CRC at lunch time.
Old Aug 16, 2006 | 03:04 PM
  #41
Modded Member
Any idea where I can find the CRC here locally?
Old Aug 16, 2006 | 03:48 PM
  #42
JOKER's Avatar
CLUB MODERATOR
I got a Q for you.
How long did that last?
Because it thinks it might be the cleaner itself that was in the filter at that time that was sucked in with air and affected the performance of the engine.
Now if you guys need a cleaner for the filter you can always use COIL CLEANER or they actually do sell filter cleaners in auto stores that you can use to get rid of the oil.
Let us know if the engine performs same as it did right after you cleaned the filter
Old Aug 16, 2006 | 04:29 PM
  #43
scorcher76's Avatar
Cleaner..
Originally Posted by JOKER
I got a Q for you.
You mean the electronic contact cleaner sprayed on the filter? It did not touch the filter, in fact I had it removed while cleaning my MAF...
Old Aug 16, 2006 | 04:30 PM
  #44
gqraverice's Avatar
I got a Q for you.
I was thinking the samething.
Old Aug 16, 2006 | 04:36 PM
  #45
RXM's Avatar
RXM
I think we're onto something here
