350z springs on my 06 sedan
on
Just installed revised springs this past weekend on my '06 sedan. The only difference is the rear spring rate (its higher on the revised). I don't notice much handling difference and the revised should keep the back up just a little more than the unrevised to help balance the front and rear fender gaps.
on
Do you have the sports suspension on your Sedan? The unrevised springs will have the same spring rate and give you a 1" drop, the 05 springs are revised springs and the rears have a differentspring rate 427 vs 342 I beleive. I have read that its not a good idea to put them unrevised/revised on the non-sport sedan...not sure why unless its a shock wear issue. Can someone verify the non-sport spring issue?
Originally Posted by aronkchang
i do have the sports suspension on my sedan. will the 05 springs ruin my shocks??
Keep in mind that I do have seat time in a non sport sedan that I had for a week as a loaner for the soul purpose of checking out the that suspension (cause I made sure I was given a non sport), so I'm not just commenting just because of specs.
Originally Posted by G35m@
WARNING - Thread Hi-Jack
I've got the chance to get my hands on a set of 2007 350Z springs and shocks -
Will I have any problems with these on my 06 Sedan? Springs I have now are 04 Unrevised....
if you get the revised springs and shocks combo you'll be good to go!!i have the same setup and runs great!
on
Gsedan35...would you recommend then going with the Eibach pro-kit springs or swaping out the shocks and going with the unrevised for a non sport. I've heard mixed reviews on the pro-kit.
