Suspension Advice - 350z revised
Old Nov 9, 2006 | 01:04 AM
cloudy6MT's Avatar
I currently have 350z revised shocks and springs and the front looks much higher than than the back, it looks like my *** is sagging -- what springs would give me more of a drop in the front? eibach prokit, h&r sport, tein s-tech? any suggestions? Thanks in advance.
Old Nov 9, 2006 | 02:08 AM
Tunerz_Store's Avatar
It looks like that visually because the fenders are cut different front to rear. There is more room in the front. You could always put coupe springs in the rear and raise the car .5" to make it look like its dropped the same all the way around. But in reality it's not.
Old Nov 9, 2006 | 04:24 AM
junbug's Avatar
That's kinda strage. I have the revised springs/shocks and from what I remember, it's pretty dead even front/back. I'll have to go measure if you would like a comparison of feder to tire or feder to CL distance.
Let me know if you would like.
Jun
Old Nov 9, 2006 | 06:10 AM
jimmykce1's Avatar
There is a post on here that shows measurments with stock sports suspension, 350z springs, and 350z springs(front)/coupe springs(rear).
jimmykce1's Avatar
I am going to be installing 350z spring in front and coupe springs in the rear tomorrow.
Old Nov 9, 2006 | 06:46 AM
5150DS's Avatar
If you want to slightly raise the rear get a spacer from someone like energy suspension to even it out (cheaper than another set of springs).
Old Nov 9, 2006 | 10:04 AM
da mayor's Avatar
i dont think you should have a problem. i've had my 350z H&R springs in my sedan for 5 months now and no issues in sagging or handling
Old Nov 9, 2006 | 11:38 AM
jameyb's Avatar
As stated above, it really has to do with how the fender wells are cut. Obviously, the front wheels have to turn so they build in more gap. I solved the problem by putting coupe springs in the rear to raise it a bit. See my measurements in the thread below. I believe there are several aftermarket springs that will drop the front more than the rear to accomplish the same effect.
https://g35driver.com/forums/g35-sedan-v35-2003-06/109021-installed-unrevised-z-springsyesterday.html
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
