steering wheel removal
Old Nov 15, 2006 | 07:25 PM
rijen1013's Avatar
can some post a diy on how to remove the steering wheel please.
thanks
Old Nov 15, 2006 | 11:07 PM
ttrank's Avatar
Grocery getter
Search, there are a few.
You just pull two bolts from the side to take the airbag off and then the nut for the wheel is behind the airbag.
Old Nov 15, 2006 | 11:34 PM
mwarsh1's Avatar
you will need to take it to the dealer because you will get codes, that have to be cleared, and your car will not run right , it happend to me this is not a diy thing, it involves alot more then a few bolts.
Old Nov 15, 2006 | 11:49 PM
mwarsh1's Avatar
ok ok
Old Nov 15, 2006 | 11:50 PM
mwarsh1's Avatar
ok mitchy boy
Old Nov 16, 2006 | 01:07 AM
erdog's Avatar
I pulled mine off and replaced mine with a wheel from accordfreak. Just make sure to disconnect battery first. I actually forgot to do that the first time and had to move the car in the middle of the install and my airbag light went off and wouldn't go away. Then I found a post about how to reset it (something like turn the car to on position (without starting the car), once the airbag light goes off, turn it to off, and do that 3-4 times.
There are only 2 screws and one big nut to take off, the screws for the airbag, and the large center nut. You should get a torque wrench for the nut to make sure you put it back on with the right amount of torque (i think 23-28 ft-lb).
Old Nov 16, 2006 | 01:09 AM
ttrank's Avatar
Grocery getter
I changed mine with no problems.
Old Nov 16, 2006 | 07:08 PM
rijen1013's Avatar
thanks guys much appreciated
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
rping
Jul 26, 2015 09:53 PM
Karnicle
Jul 23, 2015 05:08 AM
