Lost
Old Dec 6, 2006 | 01:54 PM
LILShiraz's Avatar
Lost
i have a problem here, i went to change my wheels, because winter is here, and i just got around to taking off my wheels, and putting the stocks back on. so i go to the shop, and i realize that i have no idea where the key is to my wheel locks. how could i take my wheels off, the person at the shop said he could break the wheel locks, but im scared of damaging the wheels. please help!!!
Old Dec 6, 2006 | 01:56 PM
izmir41500's Avatar
G35driver Addict
did you lose the key or can you not find it? if you can't find it, it might be in the trunk with your tools. otherwise you're at a loss and they'll have to break them.
Old Dec 6, 2006 | 01:58 PM
LILShiraz's Avatar
i cant find it, i know its not in the trunk, and i checked everywhere in my house it would have been, i am gonna go to the shop and check in my car again. this really suck
Old Dec 6, 2006 | 01:59 PM
FenixL1P's Avatar
have u checked your glove compartment??? or the trunk areas as posted above?? They may have to use a nut extractor to remove the lock...
Old Dec 6, 2006 | 02:01 PM
LILShiraz's Avatar
its an after-market lock kit, not an OEM one. i had to leave my car over night at the shop, but i am going there later today to check, thanks for the help so far.
if they break the nut, it wont damage the wheel?
Old Dec 6, 2006 | 02:03 PM
Hi-TechG35's Avatar
Usually they heat the bolts up an crack the bolts. As long as they know what they are doing you shouldn't have to worry. I had mine done once before.
FenixL1P's Avatar
that's entirely up to the skill of the tech... good luck....
Old Dec 6, 2006 | 02:07 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
+1
as long as the tech knows what he's doing, you shouldnt have a problem with getting your wheels scratched. I've take off many many locks of different sizes and shapes, oem and aftermarket, and never had a problem scratching wheels.
-GP-
Old Dec 6, 2006 | 02:45 PM
gwhiz35's Avatar
Should have ordered the spare key http://www.mcgard.com/custserv/ordering_info.asp
Old Dec 6, 2006 | 02:46 PM
Floyds_racing's Avatar
Originally Posted by Gdup35sedan
+1
-GP-
^^+1 I worked at Discount tire for about 2 yrs they should be able o do it with out hurting the wheels
Old Dec 6, 2006 | 03:32 PM
ORANGEBSRT's Avatar
go to a wheel shop and see if they have a master key kit that could fit your vehicle. Someone has to have one. Good Luck
Old Dec 6, 2006 | 07:29 PM
RocketG35's Avatar
Why do I bother to DIY???
Back in the day (1992) when I had my Civic 4DR, I had a lock set where the key pattern got worn down and eventually started to get stripped (it was a poorly designed McGard lock that just wasn't durable - they no longer sell it). I had to have the lock removed, and a performance shop ended chiseling it off. Took the guy all afternoon as he took his time...no damage whatsoever to my 15" chrome MOMO Quasars (that wheel line used to be so hot...too bad their designs suck now). He only charged me $20 for a few hours of work...but that was over 10 yrs ago (it probably helped that I poured a few thousand $$$ into their shop w/my mods)!
I'm sure the newer methods (extractor/heating) are much safer than chiseling. Good luck!
Old Dec 6, 2006 | 08:04 PM
5150DS's Avatar
Sounds painful.
Old Dec 6, 2006 | 08:54 PM
jovo517's Avatar
yo just take a drill bit and drill in the middle of the lug lock it should break open without damageing your wheels
Old Dec 6, 2006 | 09:01 PM
DieselX's Avatar
What about that tool, it's like a socket that can fit onto any shape? Is it strong enough for this?
