wtf is with the gas mileage on my car??
Old Dec 10, 2006 | 12:00 PM
  #46
kevink's Avatar
My car averages 20.8 mpg, city/highway, over the last 32000 miles. Highway ranges from 22.5-26, depending on how I drive and wind speed/direction.
I would have traded a little power for better gas mileage, but I bought the car because it appealed to me.
Old Dec 10, 2006 | 12:44 PM
  #47
nghiars's Avatar
hahah i would trade a lil more gas mileage for a lil more power
im used to drivinf trucks and to get to higher speeds.. o man did it take forever and boy was i mashing the the pedal... i like trucks but figured with the way i drive. itll be cheaper to have G.
Old Dec 10, 2006 | 02:03 PM
  #48
mrdwaters's Avatar
10% Ethanol Blended Gas will reduce MPGs by ≈ 10%. And make sure you are not comparing your observed Mileage in your G with the EPA estimates of other vehicles.
Old Dec 10, 2006 | 02:24 PM
  #49
infinitialex's Avatar
as far as my g-tech,,its the old version and i have found it to be very accurate. tested the 325 with it got 15.15 1/4 mi ,went to the track with the 325.,,, got 15sec flat......i have drag slips too for those interested//
maybe my g35 has something wrong with it since its that slow
it does have a check engine light on, but its only do to some emission crap, has somehting to do with the vapor,, i was told it does not effect cars performance at all
i did not know that ethanol blend wil get better gas mileage,,,,Thank for that tip,, il try that..
Old Dec 10, 2006 | 03:08 PM
  #50
GeeWillikers's Avatar
Walking The Fine Line...
He didn't say it would IMPROVE MPG, but that it would descrease MPG.
His point was that maybe the gas you're already using is a blend.
Old Dec 10, 2006 | 05:40 PM
  #51
aaaaa,,,hmm
ok yea maybe i am,,,,lots of corn fields around here
although my sc400 didnt have a problem geting 18 in a city on the same gas:
Old Dec 11, 2006 | 01:59 AM
  #52
update,,,, got 15 mpg in city driving(
Way to go INfinity!!!!! way to make a a 260hp engine that sucks gas like it has 350,,,,
With this great engine engeneering I wonder what else I should expect from this car
Old Dec 11, 2006 | 02:11 AM
  #53
Nickk6's Avatar
Driving 80 mph on the freeway with a few trips to 90 while passing an idiot on the cell phone, I usually get 22-23 mpg. When going 65 and driving conservative, I have hit 25-28 depending on how hilly the freeway is. Mixing city in with freeway I get about 18mpg, but I am pretty heavy on the throttle.
Old Dec 11, 2006 | 02:14 AM
  #54
Nickk6's Avatar
My city is 15mpg when I am hammering the throttle constantly or driving in heavy traffic. If I cruise the speed limit and don't hit too many lights, I can get 18-20 mpg.
You must be driving hard.
Old Dec 11, 2006 | 02:16 AM
  #55
yes im driving hard and i do this with all cars that i owned ,,u can smash on gas of an e36 m3 all day long and will still get 18mpg,,,,my v8 lexus smash on gas all you want will still get you 17mpg with nearly 300hp...
Old Dec 11, 2006 | 02:59 AM
  #56
Nickk6's Avatar
I don't know what to tell you, if your full throttling it from every light and getting 15 you can't expect much more from a 3500lb car with a 3.5 liter v6. You should get a sti or evo8, you can probably get some more punch for your dollar there. More power with some what equivalent fuel economy.
Old Dec 11, 2006 | 10:15 AM
  #57
DieselX's Avatar
I would be happy with the 15mpg you're getting. I get 10 even if I try! Also, getting 15 is not far off from the EPA rating, so I dunno what you're still b!tching about. We get it, it suks, other cars get better mileage... maybe you should stick to them.
Old Dec 11, 2006 | 04:46 PM
  #58
DVatz's Avatar
Coupe 6MT
Maybe you could get that check engine light looked at again, get a second opinion. If your emissions are faulty, your engine could be running rich.
Be sure you are buying the most expensive gas (not diesel)
Don't worry about the disappointment, I almost didn't buy my G when I read a review that averaged 18 actual MPG on their test drive. But I knew what to expect when I got that sweet ride. 18 MPG is exactly what I'm getting in the city, on a long trip down south I did as well as 26 (no ethanol down there, and close to sea level!)
After you get the check engine light taken care of, get a dyno tune, a chip, or new ECM. I read somewhere (it was a catalog, mind you, and yes, they were selling something) that the G runs extremely rich after 5k rpms, losing power as well as fuel. So you may try driving below 5k in the meantime, see if that improves.
Hope that helps...
(Beware the lies of the G-tech)
Old Dec 11, 2006 | 06:02 PM
  #59
i would love to dyno tune it, but with what?
I used S-afc on my last car worked very well,,,what available for the g?
Old Dec 11, 2006 | 10:15 PM
  #60
DVatz's Avatar
Coupe 6MT
Well, dyno-tuned by an expert in the field is what I mean. It's just one of your many options to maximize the performance of your G.
