GTSpec for G35 Sedan
Old Dec 9, 2006 | 01:09 PM
jimmykce1's Avatar
I was looking at getting the three piece set for my 06 sedan. Will all of the GTSpec fit on my car with stock exhaust? Also how many of you are using the GTSpec on your sedan? Is changing your oil harder with these braces on? Please let me know what you all encountered running these baraces on the car.
Old Dec 9, 2006 | 04:28 PM
obender66's Avatar
https://g35driver.com/forums/brakes-suspension/129433-gt-spec-bars-installed-rear.html
Give me til next weekend-I will raise car again to re-torque them and I will measure distance between top of lateral bar and some reference point. PM me like next saturday
Old Dec 9, 2006 | 04:32 PM
bert039's Avatar
I have had these around my garage for months now, just been lazy to put them on. I would also like to hear the negatives with installing/using these bars.
So far I've heard that you might need an alignment after you install the bars, if you're not careful. There's also an issue with the length of the bolts while running the bars with the rear SPC camber/toe kit.
Any others?
Old Dec 9, 2006 | 05:24 PM
Floyds_racing's Avatar
I am about to start making all these products!
Old Dec 15, 2006 | 01:20 AM
chobble19's Avatar
Any others?
hmm im going to have nismo sways as well as the 3 tie braces installed with the spc camber/toe kit...any solution? ru 100%? im about to buy the lateral bar i have the front and rear just want to make sure
Old Dec 15, 2006 | 08:30 AM
bert039's Avatar
I haven't installed the tie bars yet and I don't have the SPC kit so I can't speak from personal experience but here's the link where someone else had the issue.
https://g35driver.com/forums/brakes-suspension/128070-rear-gt-spec-bar-w-aftermarket-exhaust.html
Originally Posted by G35sedan03
Here are better pics of the damaged area. I hope they can come up with a solution to this. The installation of the SPC toe bolt brought about another problem. The bolts with the SPC kit are just a little shorter than the OEM toe bolts, so even if there was no damage, there is not enough length on the bolt to also hold on to the GT bar as well, at least not enough to safely hold it. Anyone with similar issues?
Originally Posted by cato
Yeah, GTSPEC is aware of the bolt being too short. I have the rear lateral brace as well as the front. I have the coupe mid-pipe and have no banging problems.
Good luck!
The toe bolt being short and GTSpec knowing about it won't do any good since the maker of it is SPC. SPC would have to do one just a little longer. Not sure if by elongating the bolt, if that would throw off any settings. I mean if SPC makes alarger bolt, how would that affect people that do not own the GTSpec bars? All it needs is 1/4" longer and that would cover the space created by the GTSpec bar, the washer and give the nut enough thread to hold it tightly.
Old Dec 15, 2006 | 10:50 AM
chobble19's Avatar
yea i guess it is the rar tie brace affecting the alignment and spc camber kit i wonder what can be done? ....hopefully the lateral arm will work out with my HKS rear section i have on
Old Dec 15, 2006 | 11:24 AM
myG35ZX's Avatar
I have the single front and the two rear bars for about 8 months now. No issues. I wish the bolts for the rear ties were included as the OE's are a tad short, but they work. Changing the oil is no different.
Old Dec 15, 2006 | 11:51 AM
is anyone interested in custom low tie bars, rear lateral bar and 4 pt mid chassis bar for sedans?
Old Dec 15, 2006 | 11:53 AM
cato's Avatar
SouthernComfort Moderator
The GTSPEC rear lateral arm is nowhere near the HKS rear section exhaust. After talking with Ken at GTSPEC and with SIXFIVE who bought the lateral arm, we know that the lateral arm brace will not fit the coupe midpipe, but will fit the sedan. Both SIXFIVE and I have the sedan with the coupe mid-pipe. SIXFIVE demonstrated how the lateral arm bangs against the coupe middy.
Old Dec 15, 2006 | 11:54 AM
cato's Avatar
The 4 point chassis brace would be fantastic!
Old Dec 15, 2006 | 12:52 PM
chobble19's Avatar
alrighty then thanks for clearing that up guys
Old Dec 28, 2006 | 06:57 AM
jimmykce1's Avatar
I talked to the person at my preformance shop and he had to say this about GT-Spec Lateral Braces.
It makes the chasis stiffer and makes the car handle a lot better. However, he said people with some 300Z experienced paint cracking around the wheel wells. He said the chasis is so stiff that the weakest point on the car body will than flex, thus cracking paint on the car.
Any of you have had this problem on your G's?? This might take a year or so to happen.
Jusseth
Sep 13, 2020 12:25 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
laksjd84
Jul 24, 2015 05:12 PM
