What grade of gas do you use????
Old Dec 14, 2006 | 07:21 AM
nr2d's Avatar
What grade do you use in your G35's? I noticed when it started geting cold, for 3 days(!), I started hearing the clicking sound of either poor quality gas or low octane. I put a 1/2 tank of premium in and the sound has gone away. I was using regular before.
Should I start puting in "the good stuff" or just mix a 1/2 tank in ever so often? I also noticed since it has been cooler my gas mileage has gone down somewhat, 22 to 20 mpg.
Rich Dunklee
NR2D
Old Dec 14, 2006 | 08:04 AM
kevink's Avatar
I've only heard a pinging sound once in 3 years with my G35. It was low grade gas, kind of old (I hadn't driven my car much. Only 1400 miles in 3 months, which is why I haven't been back in yet for an oil change).
I'm blaming age of gas more than the octane, since it didn't happen until I was down to about 1/4 tank. Filled up, hasn't repeated.
Old Dec 14, 2006 | 08:05 AM
sloppymax's Avatar
Using lower octane can trip the knock sensor which will pull (retard) timing which can decrease both power & lower mpg. I only use top tier 93 octane.
Old Dec 14, 2006 | 08:15 AM
skeleton_cru's Avatar
Sedan
Don't be a cheapskate. Put premium gas in your premium car!
Old Dec 14, 2006 | 08:55 AM
cato's Avatar
SouthernComfort Moderator
For 88,000 miles, I have put in 93 octane with no problems ever. Why drive a super car and feed it crap?
Old Dec 14, 2006 | 10:00 AM
DieselX's Avatar
Everytime I see someone write regular or 87, I'm freaking amazed, whyyyyy.
I only use 93 and if higher was offered(in gas stations), I'd use that. I hope the previous owner of my car didn't use regular.. I'd track him down right now!
Old Dec 14, 2006 | 10:41 AM
digital1986's Avatar
https://g35driver.com/forums/g-spot/121162-what-gas-do-you-guys-fill.html
[/end thread]
Old Dec 14, 2006 | 11:19 AM
ttrank's Avatar
Grocery getter
I have to use 91 or better. Go under that and engine goes boom.
Old Dec 14, 2006 | 11:57 AM
chobble19's Avatar
93 in my G...87 in the looooaner
Old Dec 14, 2006 | 11:59 AM
cato's Avatar
1+^ I only use regular in the loaners.
Old Dec 14, 2006 | 12:02 PM
BigSash's Avatar
92 Octane, it's the highest you can get around here.
Old Dec 14, 2006 | 12:05 PM
mroleg's Avatar
Highest I can get. Usually 93.
Old Dec 14, 2006 | 12:41 PM
cfrago's Avatar
I almost always (95%) use premium and never have had any pinging or other similar noises, even when I had some regular in there. I also have the dreaded winter time gas in CT and mileage seems to go down about 10% or so. I seemed to also get lower mpg's after I put 235-50-17's on, after replacing the oem's
Old Dec 14, 2006 | 01:40 PM
gramdacious's Avatar
I use nuttin' but premium. Everytime, no exceptions. I don't think you'll ever regret getting premium. Personally I want performance. Your just not gonna get it without using premium. What is it, $0.20 extra per gallon? If I can't afford that then I shouldn't be driving a G.
Old Dec 14, 2006 | 01:50 PM
rijen1013's Avatar
all i use is premium and sometimes 100 octane
