She has twins, greddy twins that is...
#453
#461
#464
Originally Posted by ttrank
It sounds about the same as before, a little louder (bonus
), and a easier. It will blow off at 2krpm now. The problem before was at anything under ~3-4psi some boost would come out the BOV and some would go back out the turbos and you would hear a wooshhhh from air coming out of the turbos and then the air filters.
![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
it was almost like an echo effect....I was like WTF is going on......
for the last 2 days, I have been trying to figure out if I had a leak somewhere. It is good to hear that you had the same issue.
#465
Yeah it was strange. Once I added the other BOVs it got a lot better but now it's hard to tell if it's that sound or all the valves when I let off at low boost. Blow off is louder now that they are all over the place. ![Wink](https://g35driver.com/forums/images/smilies/wink.gif)
Tony (UMS) said it was ok with just the single BOV but would be a lot better on the turbos if I got a second.
