About to install coupe Middy, easy question...
Old Jan 17, 2007 | 08:29 AM
Mmagic76's Avatar
Get new OEM gaskets or reuse the old?
If getting new, I'm assuming get coupe f/r gaskets vs Sedan ones?
Old Jan 17, 2007 | 08:45 AM
sloppymax's Avatar
Personally, I would not risk a leak reusing old gaskets. Maybe if the car was brand new. Since the coupe midpipe is a straight boltup to the sedan, it will have the same flange style/dimensions and therefore the same gaskets. Nissan saves money by using the same part on multiple different vehicles.
Old Jan 17, 2007 | 09:05 AM
ILLicit's Avatar
Don't worry about it, use the same gaskets, it'll be fine.
Old Jan 17, 2007 | 09:12 AM
Mmagic76's Avatar
Will the old gaskets crack or break when I'm removing the old mid? This is a 4yr old car now.
Old Jan 17, 2007 | 09:45 AM
PDT's Avatar
PDT
If you are using the old gaskets, make sure you use some silicone gasket maker. It's available at any parts store.
Old Jan 17, 2007 | 10:02 AM
ttrank's Avatar
Grocery getter
The better idea is to get new ones but you can see when the old ones come off. In most cases you can sand the old ones a little bit and re-use them.
Old Jan 17, 2007 | 01:47 PM
jimmyc13's Avatar
Seeing you're from Ontario (winter driving/road salt) & your car is 4 yrs. old, I think it's worth just buying the new gaskets..they won't set you back that much. I replaced my middy with a coupe one a year ago, and at that time, my car was 1 1/2 yrs. old and mine weren't in the best of shape, but could have been reused. I have a feeling you'll have a lot of corrosion on yours.
Old Jan 17, 2007 | 01:53 PM
Mmagic76's Avatar
Yup, I'm thinking the same, also thinking of paying a muffler shop break and replace all the bolts with stainless ones b4 I attempt to replace the middy myself.
Old Jan 17, 2007 | 03:38 PM
Mmagic76's Avatar
Just ordered Gaskets for the middy, gaskets for the rear are different b/t the sedan and coupe, does anyone know which one I should use? I ordered the coupe gasket under the assumption that it's a coupe midpipe so it should use a coupe gasket.
Old Jan 17, 2007 | 05:25 PM
jimmyc13's Avatar
The front gaskets (2) that you need, are in the shape of the joint between the Y-pipe and midpipe and is a thin piece of 2-3 layers of metal. The rear one, however, which connects to your muffler, is a round ring, made of soft/malleable metal, which deforms & fills in the gap when you tighten it, to prevent exhaust leakage.
I have no idea what the coupe rear gasket looks like.
Old Jan 17, 2007 | 05:28 PM
Mmagic76's Avatar
That's great info, I think the parts guy said the coupe was flat and the sedan was a ring. Definitely save me an extra trip and some $ for parts.
Thanks!
Old Jan 18, 2007 | 07:33 AM
cato's Avatar
SouthernComfort Moderator
Since they don't cost too much, I replaced both when I put the coupe mid-pipe on my sedan. My 2 cents.
Old Jan 18, 2007 | 03:13 PM
SFG356MT's Avatar
while you have the exhaust off you might as well get new gaskets put on and not risk a leak
EnCr1pt3d
Jul 8, 2019 02:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
jimNC
Jul 25, 2015 05:47 AM
BlueBelleG35x
Jul 23, 2015 02:10 PM
vstypicals
Jul 20, 2015 10:55 PM
