question about wheel. needed help!
Old Jan 17, 2007 | 06:05 PM
dnr777's Avatar
I have got volk progresive ME 18-8 and offset +38 all around.
also I will order tires 225-45-18 front and 245-45-18 rear. so I wonder this set works for my car.
Old Jan 17, 2007 | 06:36 PM
SFG356MT's Avatar
If you're asking about the tires fitting on the wheels yes they will fit. If you're asking about fitment to your car that's not an issues at all.
Old Jan 17, 2007 | 07:19 PM
dnr777's Avatar
Do you guys know why people set front tire higher than rear tire. For example, front tire 225/45/18 and Rear tire 245/40/18.
Old Jan 17, 2007 | 07:47 PM
g35sedan5at's Avatar
are you sure people dont do it the other way around...i have a couple drifting buddies who have more meat on the back tires, not the front
Old Jan 17, 2007 | 07:53 PM
Chico's Avatar
225/45 is shorter and 245/45 is taller than OEM. why not just use 235/45/18 all around and you'll have a perfect set up for it?
Old Jan 17, 2007 | 09:30 PM
225/45 is not shorter than OEM and 245/45 is not taller than OEM. the number that tells you how tall is the "45".....45 is OEM so both are same height, 225 and 245 refers to WIDTH of tire.
Old Jan 17, 2007 | 09:36 PM
jameyb's Avatar
It doesn't work that way. The 45 in your example above is not a measurement, it is the aspect ratio of the tire. So for example, the height of a 225/45 is 45% of 225 millimeters and the height of a 225/35 is 35% of 225 millimeters.
So, a 245/45 is taller than 235/45 is taller than 225/45.
Old Jan 17, 2007 | 09:38 PM
dnr777's Avatar
So what kind of tire is the best for my wheel and my car?
Old Jan 17, 2007 | 09:55 PM
jameyb's Avatar
I would go with the setup Chico describes above. When it comes to wheels and tires he is definitely one of the gurus.
Old Jan 17, 2007 | 10:08 PM
Chico's Avatar
235/45/18 is the OEM spec and will fit the best on a 8" wheel. The 225 will be a bit stretched and more tucked in the front and the 245 in the rear will bulge over the rim. BTW, here are the diameters for the respective tire sizes.
225/45/18 25.9
235/45/18 26.3
245/45/18 26.6
Old Jan 17, 2007 | 10:09 PM
Chico's Avatar
exactly!!!!!!!!!!!!!
Old Jan 17, 2007 | 10:16 PM
G35Papa's Avatar
I second that. He will not steer you wrong.
235/45 and be done with it. It will fit the rim the best and look the best on an 18x8" rim. I've ran 225/45 on an 18x8 and it does have the stretched look.
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
EasySausage
Jul 14, 2015 11:17 PM
