Slip light Comes on
Old Nov 27, 2003 | 05:27 PM
G35Lakers's Avatar
Slip light Comes on
Lately when I've floored my G, the Slip light comes on for a bit. Anyone experience this? Got an auto. Any concern? What does that mean anyways?
Old Nov 27, 2003 | 06:24 PM
Msedanman's Avatar
O.F. Administrator
Re: Slip light Comes on
Probably that you're getting wheelspin. [img]/w3timages/icons/tongue.gif[/img]
GSM
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Nov 28, 2003 | 11:35 PM
ryoken's Avatar
Yup. It's the traction control engaging and slowing you down to stop the wheels from spinning. If the ground is dry and you're trying to play, turn off VDC, and you should be able to feel the difference when you floor it.
Old Nov 30, 2003 | 12:17 AM
mrman_3k's Avatar
What happens if the ground is wet and you turn off VDC when you are doing full throttle on a straight?
Old Nov 30, 2003 | 02:28 PM
booger's Avatar
you spin the chit out of them
Old Dec 1, 2003 | 04:44 AM
SkylineGT's Avatar
The slip light would still come up w/ VDC off... Happened to me before...weird...
2004 G35 Coupe 5AT
Black/Graphite Ltr
Tire Pkg
Old Dec 1, 2003 | 08:19 AM
cato's Avatar
SouthernComfort Moderator
It's called "Traction Control", separate from the "Vehicle Dynamic Control". You can turn the VDC off, but can't turn off the TC.
2003 Twilight Blue 5AT Sedan, sunroof,
Graphite Leather, splashguards,
DB/GroundingGear red 12 wire Hyper-grounding kit,
350Z intake duct, Stillen Hi-Flow Airbox
Underbody rear diffusers
Old Dec 1, 2003 | 11:54 AM
ryoken's Avatar
Traction control and Stability control are both parts of VDC (Vehicle Dynamic Control) -- and they both get turned off. All that's left on is the "Brake LSD" subsystem that brakes one rear wheel if it's spinning faster than the other rear wheel.
If you're already moving fast on the wet ground when you turn off the system, not much would happen. If you floor it from a start or low speed, you'll spin the tires.. and possible make the back end swing around if you don't know how to steer in that situation.
Old Dec 1, 2003 | 11:59 AM
3point5SE_Auto's Avatar
under EXTREME circumstances even with the VDC off, the TC will still activate as it is never completely off unless you pull the stop lamp fuse inthe fuse box.
In my 6 mt when I was learning how to launch I played around with 5k drops a couple times and had VDC off, TC still worked, light still came on and my tires only spun for about 5 seconds. With the stop lamp fuse pulled you can spin for as long as you want.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Custom Catback, Custom Intake Tube, HyperGround Kit
Mry
Mar 3, 2023 01:03 AM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
